chrisoma
Wine and Mono
Mon Apr 18, 2016 3:07 pm
Hello. I'm trying to use Wine to run an application, but this report that I need to install "Mono for Windows"
I supposedly did it but now I'm not sure how to call it correctly.
i.e Normally I use this command 'wine application.exe'
But as it requested to use Mono for Windows I'm not sure if this should change to 'mono application.exe' or 'wine mono application.exe'
Anyway I tried both and none of them works...
Any idea about the right way, just to confirm the correct path to follow....
hal8000
Re: Wine and Mono
Mon Apr 18, 2016 8:05 pm
You ideally need to state the name of the program you are trying to run
and paste the error message from the terminal/
have a look at the Wine DB to see if anyone has your app working:
https://appdb.winehq.org/
ghans
Re: Wine and Mono
Tue Apr 19, 2016 5:35 am
Why are you using Wine AND Mono ? Usually Mono
should be enough IF the app is pure .NET code.
Also , when you're at it why Mono instead of Microsofts
CLR on top of WINE ?
Furthermore WINE does NOT work on ARM machines directly
and was never meant to - getting the App to work
directly on the Pi through Mono is the way forward.
ghans
fsck
Re: Wine and Mono
Tue Apr 19, 2016 6:08 am
So this thread is not about alcohol and STDs?
