req
Re: The device as a server
Tue Nov 22, 2011 7:36 pm
Hello! I\'m new to hardware and to such hands-on projects, but the device looks fantastic. Would it be feasible to use the device as a development server that I can leave on at all times? I\'ve been wanting one for quite a while. I would use it like any other linux box running apache, ssh, mysql etc. Would that work? I\'d love smbd and a X desktop with fluxbox as well, but would they be too heavy?
Can\'t wait to start playing with the device when it is released and can\'t wait to start learning what I can do with it and how.
matt_heys
Tue Nov 22, 2011 7:44 pm
I think it should be fine for that. It\'s not an amazingly fast CPU however, so compiling massive amounts of C code might be a bit slow.
Are you mainly planning on developing web applications on a LAMP stack with something like PHP? should be fine if you are, that is one of the reasons I want one, write my own webapps.
kme
Tue Nov 22, 2011 7:58 pm
Mysql could easily max out the RAM, but the rest seems reasonable if your aren\'t too demanding.
req
Tue Nov 22, 2011 8:18 pm
Webapps are indeed mostly what I make, but I\'m interested in developing my skills in well, everything. If the pi can handle a lamp stack, it will be enough for whatever I want to try - graphics and cpu heavy things don\'t really feel like something that I\'d do for a long time.
kaedroho
Tue Nov 22, 2011 8:43 pm
I got a PC running ubuntu server, apache, mysql and ssh with 256 MB of RAM.
I just had to tweak mysqls caching settings to prevent it maxing the RAM.
yoonsikp
Tue Nov 22, 2011 11:06 pm
Just remember, the Raspberry Pi has a good gpu, so you might be looking at something more multimedia oriented
Skygod
Wed Nov 23, 2011 9:59 am
[quote]Quote from req on November 22, 2011, 19:36
Can\'t wait to start playing with the device when it is released and can\'t wait to start learning what I can do with it and how.[/quote]
A full LAMP server running on 256Mb is easily attainable and practiacl as that\'s all I have on my VPS with CentOS 5.5,
Running an X desktop as well would probably be impractical, but you can always run X client over ssh back to another system to handle most admin functions that you prefer to do through a GUI.
RadioactiveMouse
Wed Nov 23, 2011 11:06 am
I guess you could run node.js and other servers as well as the traditional LAMP stack ;)
I intend it to be a node daemon and possible switch to python system for system level stuff.
Pirx-Danford
Wed Nov 23, 2011 1:11 pm
You will have to alter the mysql and apache settings so they don\'t hog all the memory, but it should be perfectly possible to use it that way :)
Davespice
Contact: Twitter
Wed Nov 23, 2011 2:51 pm
I think it would make quite a good Subversion server actually, that just needs apache and you would probably want the repositories to be on a USB disk. Certainly enough processing power there for that.
