Likeabossninja123
Sonic pi
Tue Apr 12, 2016 11:35 am
On my raspberry pi for some reason i am unable to update Sonic pi.I am currently running on version 2.6.When ever i type in the command it says that i have the latest version of sonic pi but on the website it says tha version 2.9 is out.
DirkS
Re: Sonic pi
Tue Apr 12, 2016 12:05 pm
Are you running Raspbian Wheezy?
The last version available for wheezy is 2.6, later versions are only available for Jessie.
Taxicletter
Re: Sonic pi
Tue Apr 26, 2016 9:54 pm
I have Jessie and the same problem.
--::--::- 3 x Raspberry Pi 3 - Raspbian Lite 9 - RuneAudio - one broke (wifi) - not in use -::--::--
kusti8
Re: Sonic pi
Tue Apr 26, 2016 9:57 pm
Taxicletter wrote:I have Jessie and the same problem.
1) you're running 2.6. Did you try updating? Are you sure you're running Wheezy?
2) is there a feature you need in the latest version? If not, why do you want the latest version?
Taxicletter
Re: Sonic pi
Tue Apr 26, 2016 10:11 pm
Jessie, not wheezy. Not sure which version of Sonic, just put Pi to bed.
Sonic Pi itself suggests me to update. But you tell me not to, so I guess I'll listen to you.
:P
kusti8
Re: Sonic pi
Tue Apr 26, 2016 10:14 pm
Taxicletter wrote:Jessie, not wheezy. Not sure which version of Sonic, just put Pi to bed.
:P
I'm not telling you not to, but I didn't realize it was prompting you to update.
If you can update, then do it, I'm just saying you don't always need the newest version.
Taxicletter
Re: Sonic pi
Wed Apr 27, 2016 8:16 am
OK. I understand your point.
The reason I want each update with Sonic Pi, is because now Sonic crashes with Raspbian. I have to use kernel version 4.1 to use it. And with that kernel the experimental openGL driver doesn't work.
Taxicletter
Re: Sonic pi
Thu Apr 28, 2016 6:45 pm
Anybody here uses Sonic Pi? On the latest kernel or on the 4.1 Raspbian kernel?
When I try the second example of the help, using two buffers, the sound already gets distorted. Which settings do you use?
