pxgator
Re: Cooling the Pi3 with a fan.
Sun Apr 10, 2016 3:13 am
Sorry.....I don't have a camera to take any pics so this is the best that
I can do:
http://www.ebay.com/itm/221950553658?_t ... EBIDX%3AIT
I can give you a tip though. Get rid of the thermal tape and use a very thin
coat of thermal glue. If possible you might also use a larger heatsink. Put
your fan close as possible so that the airflow is concentrated on the SOC.
Maybe a smaller diameter fan...??
So what's all this RPi stuff anyhow? Well folks, it's a feat of engineering from
the UK almost as remarkable as the De Havilland Mosquito and the Colossus.
Rive
Sun Apr 10, 2016 3:25 am
pxgator wrote:Sorry.....I don't have a camera to take any pics so this is the best that
I can do:
I ripped of that crap adhesive tape soon as i got the heatsink.
I was running AS5 thermal paste on the SoC until today. it held it fairly well too. I took it off though, and replaced it with some better thermal adhesive i had, just to see if it made any difference... made no difference at all. Maybe 1C or so. Course, I didn't let the AS5 burn in...may be worth it to go back to the thermal paste (if I can get the heatsink off now).
Maybe I'll get a smaller fan at a higher speed/CFM, or even an aluminum heatsink...
DNPNWO
pxgator
Sun Apr 10, 2016 3:37 am
Good idea. I'm a retired (old geezer) electronic technician that spent many years dealing
with cooling issues on semiconductors. Such as IGBT modules in 3 phase motor drives.
Air flow direction, concentration, and escape paths can be crucial in obtaining proper
cooling. You're on the right track so don't give up until you get the results you are needing.
Edit: @ Rive...I sent you a pm.
Rive
Wed Apr 13, 2016 6:05 pm
Thanks...Awesome!!
I managed to shave nearly 20C off Cpuburn-a53. This new heatsink (with same fan) cools at near 63C, and stress runs at 43C. I doubt I will see better results than that. idle is at 27C.
Overclocks:
dtparam=sd_overclock=100
arm_freq=1300
core_freq=500
over_voltage=4
sdram_freq=575
sdram_schmoo=0x02000020
over_voltage_sdram_p=6
over_voltage_sdram_i=4
over_voltage_sdram_c=4
v3d_freq=500
h264_freq=333
gpu_mem=256
cpuburn-a63 (63C):
[email protected]:~ $ while true; do vcgencmd measure_clock arm; vcgencmd measure_temp; sleep 10; done& ./cpuburn-a53
[1] 1514
frequency(45)=600000000
temp=30.6'C
frequency(45)=1300000000
temp=50.5'C
temp=53.7'C
frequency(45)=1299998000
temp=56.4'C
frequency(45)=1300002000
temp=58.0'C
temp=58.5'C
temp=59.1'C
temp=60.7'C
temp=61.2'C
temp=61.2'C
temp=61.2'C
temp=62.3'C
temp=62.3'C
temp=62.3'C
temp=62.3'C
temp=62.3'C
temp=62.3'C
temp=62.3'C
temp=62.3'C
temp=62.3'C
temp=62.3'C
temp=62.8'C
temp=63.4'C
temp=62.8'C
temp=62.8'C
temp=62.3'C
temp=62.3'C
temp=63.4'C
temp=62.8'C
temp=62.8'C
temp=63.4'C
temp=62.8'C
temp=63.4'C
temp=62.8'C
temp=63.4'C
temp=62.8'C
temp=63.4'C
temp=63.4'C
temp=63.9'C
temp=62.8'C
temp=63.4'C
temp=62.3'C
temp=63.4'C
temp=63.4'C
temp=63.4'C
temp=63.4'C
temp=63.4'C
temp=63.4'C
temp=63.4'C
temp=63.4'C
temp=63.4'C
temp=63.4'C
temp=63.4'C
temp=63.4'C
temp=63.4'C
temp=63.4'C
temp=63.4'C
temp=62.8'C
temp=63.4'C
temp=63.4'C
temp=63.4'C
temp=63.4'C
temp=63.4'C
temp=62.8'C
temp=63.4'C
temp=63.4'C
temp=63.4'C
temp=62.8'C
temp=63.4'C
temp=63.4'C
temp=63.4'C
temp=63.4'C
temp=63.4'C
temp=63.4'C
temp=63.4'C
temp=63.4'C
temp=63.4'C
temp=63.4'C
temp=63.4'C
temp=63.4'C
temp=63.4'C
temp=63.4'C
temp=62.3'C
temp=63.4'C
temp=63.4'C
temp=63.4'C
temp=63.4'C
temp=63.4'C
temp=63.4'C
temp=62.8'C
temp=63.4'C
temp=62.3'C
temp=63.4'C
temp=63.4'C
temp=63.4'C
temp=63.4'C
temp=63.4'C
temp=63.4'C
top - 13:52:09 up 32 min,  1 user,  load average: 4.00, 4.00, 3.40
Tasks: 137 total,   5 running, 132 sleeping,   0 stopped,   0 zombie
%Cpu0  : 99.7 us,  0.3 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
%Cpu1  :100.0 us,  0.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
%Cpu2  :100.0 us,  0.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
%Cpu3  :100.0 us,  0.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
KiB Mem:    753132 total,   512096 used,   241036 free,    34036 buffers
KiB Swap:   102396 total,        0 used,   102396 free.   353964 cached Mem
  PID USER      PR  NI    VIRT    RES    SHR S  %CPU %MEM     TIME+ COMMAND
 1517 pi        20   0    1680     84     16 R 100.0  0.0  16:07.04 cpuburn-a53
 1515 pi        20   0    1680    328    272 R 100.0  0.0  16:06.10 cpuburn-a53
 1519 pi        20   0    1680     88     16 R  99.6  0.0  15:57.17 cpuburn-a53
 1518 pi        20   0    1680     84     16 R  95.7  0.0  16:04.50 cpuburn-a53
 1032 pi        20   0   46852  19112  16416 S   2.3  2.5   0:03.97 lxterminal
  639 root      20   0  184828  50420  26516 S   1.7  6.7   0:14.60 Xorg
  869 pi        20   0   91680  24620  20360 S   0.7  3.3   0:14.16 lxpanel
  864 pi        20   0   20644  11936   9568 S   0.3  1.6   0:02.05 openbox
 1167 pi        20   0    5112   2532   2164 R   0.3  0.3   0:05.66 top
    1 root      20   0   23904   3984   2736 S   0.0  0.5   0:06.75 systemd
    2 root      20   0       0      0      0 S   0.0  0.0   0:00.00 kthreadd
    3 root      20   0       0      0      0 S   0.0  0.0   0:00.06 ksoftirqd/0
    5 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 kworker/0:+
    7 root      20   0       0      0      0 S   0.0  0.0   0:00.27 rcu_sched
DNPNWO
pxgator
Wed Apr 13, 2016 6:16 pm
Rive wrote:
Thanks...Awesome!!
I managed to shave nearly 20C off Cpuburn-a53. This new heatsink (with same fan) cools at near 63C, and stress runs at 43C. I doubtt I will see better results than that. idle is at 27C.
Your quite welcome......hope you have fun with your 'extreme pi' :D .
Edit: Some pics of your new setup??
Rive
Wed Apr 13, 2016 6:32 pm
pxgator wrote:
Rive wrote:
Thanks...Awesome!!
DNPNWO
Gerd
Sat Apr 23, 2016 9:33 am
Rive wrote:I give you 5 min tops, before you hit the ceiling, slow to a crawl, and revert to 600MHz (Hell, you probably couldn't even manage to do it with 'Stress' (which is a lightweight contender compared to cpuburn)).
C'mon, show me how wrong I am. I am waiting.
No vid, sreenshot must suffic.
cpuburn passive.png (32.4 KiB) Viewed 3296 times
Now here is my challenge for you:
Get linpack installed and get over to the linpack thread and post some numbers. My guess: with your current oc settings you are posting around you will fail. Hard.
Rive
Sat Apr 23, 2016 12:52 pm
Gerd wrote: Now here is my challenge for you:
I am not gonna hunt it down, put it here what you want me to install/run for linpack and I will give it ago.
for example, If I wanted someone to run cpuburn-a53:
wget https://raw.githubusercontent.com/ssvb/cpuburn-arm/master/cpuburn-a53.S
gcc -o cpuburn-a53 cpuburn-a53.S
DNPNWO
Rive
Sat Apr 23, 2016 1:11 pm
No pic of the pi3? What, no web cam, camera, or cell phone? Hmmm. Also, you didn't do it for the 15 min or state the ambient (you did it according to top for 8 min), or use this to show all temps (records temp and freq every 10 sec for 15 min):
Don't cheat by say putting in a chilled room, where ambient is not room temp, or under a ceiling fan/other fan, etc (that is why a vid is better (even if you just make it with your phone, and then simply upload it to google drive (if you have gmail, you have google drive) and share link https://drive.google.com/drive/my-drive ), makes it harder to fake/skew the results)
Here is the complete quote BTW:
http://www.raspberrypi.org/forums/viewt ... 62#p948462
I'd like you see one of you with the pi3 stock @ 1200 MHz (or even overclocked at a higher arm freq ), without a case, no fan, and with just a heat sink show the temps and freq in a video while running the synthetic CPUBurn-a53 for a non-stop/continuous duration of 15 min without hitting 85°C.
DNPNWO
Gerd
Sat Apr 23, 2016 2:27 pm
Rive wrote: I am not gonna hunt it down, put it here what you want me to install/run for linpack and I will give it ago.
I just followed viewtopic.php?p=926798#p926798 .
Gerd
Sat Apr 23, 2016 2:39 pm
Rive wrote:No pic of the pi3?
I thought you would follow that thread.
viewtopic.php?p=957234#p957234
No cheating. Ambient 20°C.
And the cooler isn't mounted yet, just lying planar an the CPU. Glued and vertical it will show its full potential.
Rive
Sat Apr 23, 2016 2:48 pm
I see links and instructions for downloading, and compiling code....I don't have time for all that. I am not gonna jump through hoops for linpack (make it simple, do step by step instructions...like this example for setting up sdbench)
for example, sdbench:
open, and 'select all':
http://www.nmacleod.com/public/sdbench.sh
Copy the text, then open a terminal and type...
sudo nano sdbench.sh
...and paste the text in, then save with Ctrl-X, Y, Enter.
Make it executable with...
sudo chmod +x sdbench.sh
Then run:
sudo ./sdbench.sh
DNPNWO
Gerd
Sat Apr 23, 2016 3:30 pm
I see links and instructions for compiling code....I don't have time for all that. I am not gonna jump through hoops for linpack.
No compiling, what is so hard to follow: "Alternately, you can install gfortran and libmpich-dev libs and then the following binary shoud work:
http://web.eece.maine.edu/~vweaver/junk/pi3_hpl.tar.gz " in the post i linked?"
OK, i prepare some fast food:
sudo apt-get install libmpich-dev
gfortran should install also.
cd ~
wget http://web.eece.maine.edu/~vweaver/junk/pi3_hpl.tar.gz
tar -xvzf pi3_hpl.tar.gz
chmod +x xhpl
./xhpl
Later with
nano HPL.dat
you can change the N from 8000.
Enjoy!
Rive
Sat Apr 23, 2016 3:36 pm
Finished 1 tests with the following results:
0 tests completed and passed residual checks,
0 tests completed and failed residual checks,
1 tests skipped because of illegal input values.
End of Tests..
HPL.dat
HPLinpack benchmark input file
Innovative Computing Laboratory, University of Tennessee
HPL.out      output file name (if any)
6            device out (6=stdout,7=stderr,file)
1            # of problems sizes (N)
8000            Ns
1            # of NBs
256             NBs
0            PMAP process mapping (0=Row-,1=Column-major)
1            # of process grids (P x Q)
1         Ps
1         Qs
16.0         threshold
1            # of panel fact
0          PFACTs (0=left, 1=Crout, 2=Right)
1            # of recursive stopping criterium
2           NBMINs (>= 1)
1            # of panels in recursion
2            NDIVs
1            # of recursive panel fact.
2         RFACTs (0=left, 1=Crout, 2=Right)
1            # of broadcast
2            BCASTs (0=1rg,1=1rM,2=2rg,3=2rM,4=Lng,5=LnM)
1            # of lookahead depth
0            DEPTHs (>=0)
2            SWAP (0=bin-exch,1=long,2=mix)
64           swapping threshold
0            L1 in (0=transposed,1=no-transposed) form
0            U  in (0=transposed,1=no-transposed) form
1            Equilibration (0=no,1=yes)
8            memory alignment in double (> 0)
[email protected]:~ $ ./xhpl
HPLinpack 2.1  --  High-Performance Linpack benchmark  --   October 26, 2012
Written by A. Petitet and R. Clint Whaley,  Innovative Computing Laboratory, UTK
Modified by Piotr Luszczek, Innovative Computing Laboratory, UTK
Modified by Julien Langou, University of Colorado Denver
An explanation of the input/output parameters follows:
T/V    : Wall time / encoded variant.
N      : The order of the coefficient matrix A.
NB     : The partitioning blocking factor.
P      : The number of process rows.
Q      : The number of process columns.
Time   : Time in seconds to solve the linear system.
Gflops : Rate of execution for solving the linear system.
The following parameter values will be used:
N      :    8000
NB     :     256
PMAP   : Row-major process mapping
P      :       1
Q      :       1
PFACT  :    Left
NBMIN  :       2
NDIV   :       2
RFACT  :   Right
BCAST  :   2ring
DEPTH  :       0
SWAP   : Mix (threshold = 64)
L1     : transposed form
U      : transposed form
EQUIL  : yes
ALIGN  : 8 double precision words
- The matrix A is randomly generated for each test.
- The following scaled residual check will be computed:
      ||Ax-b||_oo / ( eps * ( || x ||_oo * || A ||_oo + || b ||_oo ) * N )
- The relative machine precision (eps) is taken to be               1.110223e-16
- Computational tests pass if scaled residuals are less than                16.0
HPL ERROR from process # 0, on line 173 of function HPL_pdtest:
>>> [0,0] Memory allocation failed for A, x and b. Skip. <<<
End of Tests.
DNPNWO
Gerd
Sat Apr 23, 2016 3:57 pm
Rive wrote:something isnt right (do i need to manually set memory allocation?
Never had this, maybe because i run my Pi3 headless with gpu_mem=48. I guess you run gpu mem with 256. I would try lower it for this test to 64 in config.txt
Edit: or lower to N=6000 for the start.
Rive
Sat Apr 23, 2016 4:21 pm
I set gpu mem to 64, and used 6000
I then disabled all overclocks, and ran with pi3 stock speeds and values ONLY for sdcard, core, sdram, voltages, and the arm. The test failed with the below parameter values.
N      :    6000
NB     :     256
P      :       1
Q      :       1
PFACT  :    Left
NBMIN  :       2
NDIV   :       2
RFACT  :   Right
BCAST  :   2ring
DEPTH  :       0
U      : transposed form
EQUIL  : yes
T/V                N    NB     P     Q               Time                 Gflops
WR02R2L2        6000   256     1     1              24.34              5.919e+00
HPL_pdgesv() start time Sat Apr 23 12:18:55 2016
HPL_pdgesv() end time   Sat Apr 23 12:19:19 2016
||Ax-b||_oo/(eps*(||A||_oo*||x||_oo+||b||_oo)*N)= 4802590957.1838751 ...... FAILED
||Ax-b||_oo  . . . . . . . . . . . . . . . . . =          29.178269
||A||_oo . . . . . . . . . . . . . . . . . . . =        1540.184305
||A||_1  . . . . . . . . . . . . . . . . . . . =        1543.558216
||x||_oo . . . . . . . . . . . . . . . . . . . =           5.921421
||x||_1  . . . . . . . . . . . . . . . . . . . =        5989.406088
||b||_oo . . . . . . . . . . . . . . . . . . . =           0.499944
              1 tests completed and failed residual checks,
              0 tests skipped because of illegal input values.
End of Tests.
DNPNWO
Rive
Sat Apr 23, 2016 6:15 pm
passed @ 6000 with gpu_mem=64 for following overclock settings:
arm_freq=1275
core_freq=500
over_voltage=4
sdram_freq=575
v3d_freq=500
h264_freq=333
N      :    6000
NB     :     256
P      :       1
Q      :       1
PFACT  :    Left
NBMIN  :       2
NDIV   :       2
RFACT  :   Right
BCAST  :   2ring
DEPTH  :       0
U      : transposed form
EQUIL  : yes
WR02R2L2        6000   256     1     1              21.99              6.552e+00
HPL_pdgesv() start time Sat Apr 23 14:11:12 2016
HPL_pdgesv() end time   Sat Apr 23 14:11:34 2016
||Ax-b||_oo/(eps*(||A||_oo*||x||_oo+||b||_oo)*N)=        0.0028294 ...... PASSED
              1 tests completed and passed residual checks,
End of Tests.
passed @ 8000 with gpu_mem=64 for following overclock settings:
arm_freq=1250
core_freq=500
over_voltage=4
sdram_freq=575
v3d_freq=500
h264_freq=333
N      :    8000
NB     :     256
P      :       1
Q      :       1
PFACT  :    Left
NBMIN  :       2
NDIV   :       2
RFACT  :   Right
BCAST  :   2ring
DEPTH  :       0
U      : transposed form
EQUIL  : yes
WR02R2L2        8000   256     1     1              51.15              6.675e+00
HPL_pdgesv() start time Sat Apr 23 14:23:43 2016
HPL_pdgesv() end time   Sat Apr 23 14:24:34 2016
||Ax-b||_oo/(eps*(||A||_oo*||x||_oo+||b||_oo)*N)=        0.0025941 ...... PASSED
End of Tests.
arm_freq=1260
core_freq=500
over_voltage=4
sdram_freq=575
v3d_freq=500
h264_freq=333
N      :    8000
NB     :     256
P      :       1
Q      :       1
PFACT  :    Left
NBMIN  :       2
NDIV   :       2
RFACT  :   Right
BCAST  :   2ring
DEPTH  :       0
U      : transposed form
EQUIL  : yes
WR02R2L2        8000   256     1     1              50.63              6.743e+00
HPL_pdgesv() start time Sat Apr 23 14:38:56 2016
HPL_pdgesv() end time   Sat Apr 23 14:39:47 2016
End of Tests.
DNPNWO
Gerd
Sat Apr 23, 2016 6:40 pm
As I said before, you had to lower clock from your posted settings. Why not put it the other way round. NO oc at all, NO cpu , NO ram, just NO; only over_voltage. And then lets see when you get the first correct pass.
Edit: And remember: I did N=10000 with passive cooling viewtopic.php?p=959556#p959556
Rive
Sat Apr 23, 2016 6:43 pm
Gerd wrote:As I said before, you had to lower clock from your posted settings. Why not put it the other way round. NO oc at all, NO cpu , NO ram, just NO; only over_voltage. And then lets see when you get the first correct pass.
Ok. So, you mean run stock, BUT with just the over voltage?
Also, third 8000 passed @ 1260 MHz
DNPNWO
Rive
Sat Apr 23, 2016 6:52 pm
passed at 8000 stock overvolt/overvolt sdram only as shown (Abient 20C, linpack @55C)
over_voltage=4
N      :    8000
NB     :     256
P      :       1
Q      :       1
PFACT  :    Left
NBMIN  :       2
NDIV   :       2
RFACT  :   Right
BCAST  :   2ring
DEPTH  :       0
U      : transposed form
EQUIL  : yes
WR02R2L2        8000   256     1     1              54.70              6.241e+00
HPL_pdgesv() start time Sat Apr 23 14:49:46 2016
HPL_pdgesv() end time   Sat Apr 23 14:50:41 2016
End of Tests.
passed at 8000 stock with over_voltage only
over_voltage=4
N      :    8000
NB     :     256
P      :       1
Q      :       1
PFACT  :    Left
NBMIN  :       2
NDIV   :       2
RFACT  :   Right
BCAST  :   2ring
DEPTH  :       0
U      : transposed form
EQUIL  : yes
WR02R2L2        8000   256     1     1              54.59              6.255e+00
HPL_pdgesv() start time Sat Apr 23 14:55:29 2016
HPL_pdgesv() end time   Sat Apr 23 14:56:23 2016
End of Tests.
DNPNWO
Gerd
Sat Apr 23, 2016 7:04 pm
Yes, but i meant NO oc, not even ram. What I expect you will find, is that you need over_voltage = 2 or 1 to run it at stock (=NO oc) settings. This means, that you have to overvolt your pi to get the correct answer for a linear equation. This should not hapen.
Rive
Sat Apr 23, 2016 7:05 pm
Gerd wrote:Yes, but i meant NO oc, not even ram. What I expect you will find, is that you need over_voltage = 2 or 1 to run it at stock (=NO oc) settings. This means, that you have to overvolt your pi to get the correct answer for a linear equation. This should not hapen.
passed at 8000 stock with over_voltage=4 only
Do you want me to retest with over-voltage at 2? I have already verified it fails at stock with no over_voltage at all.
over_voltage=4
N      :    8000
NB     :     256
P      :       1
Q      :       1
PFACT  :    Left
NBMIN  :       2
NDIV   :       2
RFACT  :   Right
BCAST  :   2ring
DEPTH  :       0
U      : transposed form
EQUIL  : yes
End of Tests.
DNPNWO
Rive
Sat Apr 23, 2016 7:16 pm
passes at 8000 stock with over voltage =1
over_voltage=1
N      :    8000
NB     :     256
P      :       1
Q      :       1
PFACT  :    Left
NBMIN  :       2
NDIV   :       2
RFACT  :   Right
BCAST  :   2ring
DEPTH  :       0
U      : transposed form
EQUIL  : yes
WR02R2L2        8000   256     1     1              55.37              6.166e+00
HPL_pdgesv() start time Sat Apr 23 15:14:17 2016
HPL_pdgesv() end time   Sat Apr 23 15:15:12 2016
End of Tests.
DNPNWO
Rive
Sat Apr 23, 2016 8:09 pm
Instead of hijacking this thread for linpack bench, I have started a new overclocking linpack/cpuburn thread here:
viewtopic.php?p=959884#p959884
DNPNWO
Gerd
Sat Apr 23, 2016 8:32 pm
Rive wrote:Instead of hijacking this thread for linpack bench, I have started a new overclocking linpack/cpuburn thread here:
Instead of opening annother thread you could as well have posted your results in the referenced linpack thread viewtopic.php?f=63&t=139712
