minecraftjien
Can cracked minecraft work with raspberry pi 3?
Thu Apr 07, 2016 2:06 pm
{MOD EDIT - POST DELETED - WE DO NOT ALLOW DISCUSSIONS ON ILLEGAL OR PIRATED SOFTWARE ON THIS FORUM]
scotty101
Re: Can cracked minecraft work with raspberry pi 3?
Thu Apr 07, 2016 2:19 pm
By cracked do you mean illegally downloaded?
If so, you aren't going to get any help here.
mathboy4life
Thu Apr 07, 2016 2:21 pm
The guide says
update MINECRAFT_LOGIN, MINECRAFT_USERNAME and MINECRAFT_PASSWORD to your own
The only way to get them is by https://minecraft.net/store
rpiMike
Thu Apr 07, 2016 9:31 pm
Buy the genuine version of Minecraft to encourage more awesome game development.
Oldbitcollector
Fri Apr 08, 2016 12:00 am
Try minetest instead..
Here's an excellent article on it along with install instructions about half-way down.
http://www.ocsmag.com/2016/04/04/mining-for-education/
My Ongoing Raspberry Pi Reference: http://www.ledgerlabs.us/raspberrypi
Bottersnike
Fri Apr 08, 2016 6:14 am
In the past, when I tried to run the jar of minecraft (I think it was 1.6 at the time) I found that it was unable to run on an arm architecture. I also think that minecraft cant handle opengles but I'm fairly sure you can get opengl for the pi 3 now. Even if it could run, the pi doesn't have nearly enough ram to play ;)
Micro:Pi is an (almost) fully fledged IDE for programming a BBC Micro:Bit using C++. Go check it out at https://bottersnike.github.io/Micro-Pi
