KeithSloan
Cups & HP Business Inkjet 1200
Tue Apr 05, 2016 2:09 pm
I had a problem with my Pi following a power failure and decided to rebuild my system using Jessie rather than Wheezy.
I had it working as a Cups print server for an HP Business Inkjet 1200n with Wheezy. Installed a long time ago so not sure how I got it working.
Under Jessie cups installation when asked for the model, HP Business Inkjet 1200 does not show up. Tried entering Model 2220 which allows me to print a test page from cups, but not from any of the machines I am trying to serve
ie. ipp://pi-two.local:631/printers/HP_Business_Inkjet_1200
Rive
Re: Cups & HP Business Inkjet 1200
Tue Apr 05, 2016 2:31 pm
for HP, try:
sudo apt-get install hplip
sudo hp-setup -i
DNPNWO
Tue Apr 05, 2016 2:34 pm
KeithSloan wrote:I had a problem with my Pi following a power failure and decided to rebuild my system using Jessie rather than Wheezy.
You are likely missing the HPLIP package which when installed should offer more drivers in CUPS set up:
sudo apt-get update
Thinking outside the box is better than burying your head in the sand...
KeithSloan
Tue Apr 05, 2016 3:19 pm
Rive wrote:for HP, try:
sudo hp-setup -i
That got me further, but when I do a test print from ubuntu the job gets status held for authentication. If I right click and authenticate it does not work.
But any way I think I have to change some option in /etc/cups/cupsd.conf
In the bit that follows
# All printer operations require a printer operator to authenticate...
KeithSloan
Tue Apr 05, 2016 4:21 pm
sudo hp-setup -i
Selecting share printer fixed things.
