Pi 3 and a webcam
Posted: Mon Apr 04, 2016 8:45 am
by PeersC
Hi there,
I wonder if anyone can help me - I am trying to get an HD webcam to work with my Pi3 that I have just bought, I am old enough to remember MSDOS so debian is not altogether a stranger - I have programmed in C☺and java so python is making sense as well. However, I am not having a great deal of success at getting a webcam to run (I will eventually want more than one camera). I know my camera are Pi compatible because on one of my attempts I managed to get a load of still images onto the Pi just could not remember exactly what I had done (note to self - make NOTES!!!).
This is where I am up to :-
update, upgrade, rpi-update
Installed motion and libav-tools
I have edited the motion.conf file for what has been recommended but not able to connect to pi and webcam from my LAN - my DHCP server always seems to prefer the pi on 192.168.1.172 but I do check it each time - I will allocated a static IP and port forward to it when I am ready but want to get something working first.
All that happens is I start service motion and try and connect on another machine and just get website not found or is busy or not responding error.
Also I cannot seem to find in the motion.conf file a choice for my captured files to be stored - the PI has a USB drive for this purpose on the dir /media/USB
Anyone got any ideas where to head next???
Peers
As a footnote = when I edit motion.conf the deamon is already set to on and there is no mention of the webcam_localhost setting at all - this is supposed to be set to off??
Now getting an avi file and loads of jpg's on my USB drive - Motion log file says it is streaming on port 8081 but still cannot access stream through browser on another machine is there a permission I need to change?
All working now motion.conf needs editing differently from previous versions checking through motion.log file showed me what was wrong :>)))
Re: Pi 3 and a webcam
Posted: Tue Apr 05, 2016 10:17 am
by SelvaS
Hi, I am currently facing the same issue. Could you please elaborate how you managed to fix this?
Selva
Posted: Wed Apr 06, 2016 8:41 am
by PeersC
Hi Selva,
I'll do my best but I am assuming that the issue is a fundamental difference between a Pi 2 (Wheezy) and a Pi 3 (Jessie) and the differences if I am wrong then I'll hold my hand up. Also the differences between ffmpeg and libav-tools.
#firstly check all is up to date
sudo apt-get install rpi-update
sudo rpi-update
sudo apt-get update
sudo apt-get upgrade
#Now for our camera bits and bobs
sudo apt-get install motion
sudo apt-get install libav-tools
#Now plug in your camera and see if the Pi recognizes it with lsusb command
lsusb
#you should see something like this :-
Bus 001 Device 005: ID ????:???? Something to do with your camera's chipset
# Now it is time to take a look at motion.conf - this is the configuration file that tells your camera what it is supposed to be doing - (if you are following tutorials from the web) this is where you notice something is amiss.
sudo nano /etc/motion/motion.conf
#one of the first thing that differs from the tutorial is that daemon is already on (the default if off) it should be ON - The second is that webcam_localhost doesn't exist ??? this is where things start to go wrong - the config files are slightly different . look for two things logfile and target_dir and make a note of the paths leading to those files. Also change the entry stream_localhost to off this allows streaming to other computers on the local network. Also change the entry webcontrol_localhost to off this allows you to control pan/tilt and zoom remotely if your camera supports it. I also changed the entry output_pictures to first. This means that only the first frame of the stream is saved to the path named in target_dir
Press ctrl-X to save and exit
#to run motion
sudo nano etc/default/motion
# change start_motion_daemon to yes save and exit
# start by typing
sudo service motion start
# that should in theory do it you can check by pointing your browser to the IP addy of your Pi with :8081 at the end ex 192.168.1.172 or if you are unsure then use ifconfig to find out.
# If it doesn't work look at the log file motion.log in the dir pointed to in the motion.conf - This will give you some idea of what works and doesn't and edit accordingly. Hope this helps
Peers
Posted: Mon Apr 11, 2016 5:13 pm
by PeersC
Hi there,
Just looking to see if the suggestions worked??
Did for me - any feedback greatly appreciated
Peers
Posted: Wed Apr 20, 2016 8:50 am
by ks009
:D Thanks Peers.
All worked except the daemon couldn't write because of a permission issue. This post resolved that for me:
http://raspberrypi.stackexchange.com/qu ... -directory
Posted: Sat Jul 22, 2017 6:47 am
by allscan12
Could anyone help me why the webcam I connected to my Pi3 is blurry?
Here are my settings after installing "Motion":
Framerate = 10
Stream_quality = 100
Quality = 100
Width = 640
Height = 480
Post_capture = 5
Stream_localhost = off
Webcontrol_localhost = off
Start_motion_daemon=yes
The webcam is working, however it is blurry. Any help will be highly appreciated. Thanks.
Allscan12
