ConradG13
Re: Need some help!- project!- IMPORTANT!
Sun Apr 17, 2016 3:29 am
Yeah, I figured out how to start at boot but, the script isn't working. That's is what I'm trying to figure out right now.
People who say times instead of multiply shouldn't be around.
ConradG13
Sun Apr 17, 2016 3:32 am
Now the only error I am receiving is
[email protected]:~ $ /etc/init.d/radio
numid=3,iface=MIXER,name='PCM Playback Route'
  ; type=INTEGER,access=rw------,values=1,min=0,max=2,step=0
  : values=1
  File "/home/pi/radio.py", line 10
    [email protected]:~$ /etc/init.d/radio
IndentationError: expected an indented block
stderr
Sun Apr 17, 2016 4:37 am
ConradG13 wrote:Now the only error I am receiving is
  : values=1
I'm curious if the following runs at the command line:
mplayer -playlist http://bbc.co.uk/radio/listen/live/r6.asx
Sun Apr 17, 2016 5:06 am
As far as I can tell your code radio.py contains the lines:
    if GPIO.input(23)==1:
Which is not valid Python.
Firstly Python expects white space indentation after an "if"
Secondly you have pasted your command prompt into the code "[email protected]:~ $ /etc/init.d/radio"
Thirdly even without that you cannot just run a command from Python like that. You need to do it as described here:
http://fastml.com/how-to-run-external-p ... ir-output/
