procount
Re: STICKY: PINN - An enhanced version of NOOBS.
Wed Oct 02, 2019 7:18 pm
PINN FULL has not been updated yet for offline installation, but any version of PINN will always use the latest version of Raspbian if connected to the internet
PINN - NOOBS with the extras... https://www.raspberrypi.org/forums/viewtopic.php?f=63&t=142574
procount
Sun Oct 13, 2019 8:51 pm
PirateBox is now available through PINN.
procount
Sun Oct 13, 2019 10:28 pm
Retropie updated to v4.5.1
max11
Mon Oct 21, 2019 12:44 pm
after several days of not touching Pinn at all (v.3.3c - July 24 2019) - just let it boot - i wanted to backup my perfectly running Raspbian.
This is now impossible - it worked before .Now i get the attached message,
And at the start Pinn tells me "Error downloading distribution List..." Pic attached.
Where is my problem?
Thanks in advance
Max11
procount
Mon Oct 21, 2019 1:33 pm
It looks like you installed:
  • Raspbian FULL,
  • Retropie2
  • LibreELEC_rpi2
  • Xbian_rpi3
  • ProjectSpace-1
using Matt's webs page to customise the partition sizes.
The first error message is due to my mistake. :oops:
I have just updated retropie to v4.5.1 and inadvertently changed its name from retropie2 to retropie3. Matt's webpage can therefore no longer find the original files and errors out. Apologies. I have just restored the old retropie2, so it should work again, although you might have to wait up to 24 hours for Matt's webpage to refresh its data. In the meantime, you could try a couple of things:
1. exclude retropie from the backup
2. Edit recovery.cmdline and remove the 'alt_image_source="...." option
3. Try only selecting 1 OS at a time to backup, to avoid errors in one OS preventing you backing up the others. Then post what is still problematic.
It should be possible to backup raspbian_full, so I'm not sure why it claims an update is required. Maybe that is due to the first error, or it could just be due to the version of Raspbian you installed - what version/date do you have installed? If removing alt_image_source does not fix it, let me know and we will fix it another way.
It will not be possible to backup Xbian using PINN because it uses a BTRFS file system. You will have to do this manually, I'm afraid.
Sorry for the unexpected inconvenience.
max11
Mon Oct 21, 2019 4:09 pm
thank you for your fast response.
I didn't want to backup retropie (deleted already a few months ago from Pinn)
I only had checked Raspbian full for backup. That was the only OS.
Before i try other things i will wait for the correct list on Matts side and see if that changes the behaviour.
Xbian is also already deleted months ago - but it still shows up in the download error. I will remove the alt_image_source...option.
Although i think it is not the reason for the error, as all earlier backups were perfect.
I think the second error is depending on the first (unable to download) error.
Let's wait and see.
It is not a real üproblem for me , so don't worry ;)
Regards
Max11
max11
Wed Oct 23, 2019 12:06 pm
So today i started another try to backup Raspbian.
The first result (changing nothing) resulted in the same error messages as mentioned above..
I then changed recovery.cmdline and started Pinn again.
Result: the Start-message doesn't show anymore,
but it is still impossible to make a backup of Raspbian.
https://www.raspberrypi.org/forums/down ... w&id=32717
The error-message is the same as before.(unsupported ....)
Any ideas?
Attached my Pinn configuration.
Regards
Max11
max11
Wed Oct 23, 2019 12:29 pm
ok,
just tested the other backups.
Libreelec : no problem
Openplotter and Raspbian : both unable to backup ... unsupported ...
procount
Wed Oct 23, 2019 12:40 pm
I meant that you should remove the whole of the "alt_image_source" option, not just the part between the quotes.
You will also need to remove the "no_default_source" option and ensure you are connected to the internet.
max11
Wed Oct 23, 2019 6:29 pm
Yesssss :D :D
I changed recovery cmdline according to your suggestion and everything is working again.
Thank you, Procount
BRX7
Thu Oct 24, 2019 3:05 pm
Any new dates since 3.3c?
procount
Thu Oct 24, 2019 3:12 pm
Not yet, but working on the next release. ;)
DalaMicke
Batocera ha moved to new website
Sat Nov 09, 2019 10:42 am
I have a RasBerry 3B+ and using PINN v3.3c
I am trying to install Batocera in PINN, but the installation will fail.
In the debug-log I can see that the install-script is trying to use the link:
http://batocera-linux.xorhub.com/
But now the Batocera has moved to another website: https://batocera.org/
So the install-script will not work anymore.
Is it possible to install Batocera manually or change the install-script?
I can download the RasBerry image from the new website, but how to change the install script to use the image I downloaded my self?
mattrix
Sat Nov 09, 2019 8:12 pm
@DalaMicke
Should be sorted now :)
Just reboot and try to install again.
www.matthuisman.nz
DalaMicke
Mon Nov 11, 2019 11:06 pm
Now It works!
Thanks for fast support!
