When I run it with no options(or with -o hdmi), it displays: "have a nice day
H264 - MPEG-4 AVC (part 10) (avc1)
Encoded by: x264
Is this format not supported by omxplayer? I've reinstalled omxplayer and its dependancy and it hasn't helped. Running on a pi 2. The file is a screencast from Kazam (25fps). Running under sudo doesn't help either.
EDIT: after reboot, when I try to play the video(with -o hdmi), I get a mostly yellow window and nothing happens. I have to use alt-f4 to quit omxplayer. Omxplayer's output is:
Video codec omx-h264 width 800 height 480 profile 244 fps 25.000000
Subtitle count: 0, state: off, index: 1, delay: 0
V:PortSettingsChanged: 800x480@25.00 interlace:0 deinterlace:0 anaglyph:0 par:1.00 display:0 alpha:255 aspectMode:0
If I try to play the same video again immediately after, I get this without any other video output (no yellow square):
If I play the video without -o hdmi, the same thing happens with the yellow square but omxplayer does quit with q.
