femindharamshi10
php error 500
Fri Mar 25, 2016 2:35 pm
i have set up a apache2 web server on my pi and install php5 and all.
i places a simple php in the server and when i run it, it says,
<pi-ip-address> page isn’t working
<pi-ip-address> is currently unable to handle this request.
500
how do i fix this ?
pksato
Re: php error 500
Fri Mar 25, 2016 4:36 pm
femindharamshi10 wrote:i have set up a apache2 web server on my pi and install php5 and all.
500
how do i fix this ?
Hi, Sorry.
I don't know how fix it.
I don't know that causing this error.
You need to check apache error log to see that is cause of this error.
Open a root shell on rpi and run
tail -f /var/logs/apache2/error.log
and from browser, access php script.
If not understand the log, copy relevant text (not screenshot) and past here.
tip.:
If accessing rpi from other computer using ssh on a graphical environment, or is on local (rpi) gui, you can copy text only selecting, and past using middle mouse button. Or using copy/past option on terminal emulator menu. Also, is possible to copy and past using text only console, but, need to run gpm daemon.
femindharamshi10
Re: php error 500
Fri Mar 25, 2016 6:21 pm
500
how do i fix this ?
Hi, Sorry.
tip.:
i got the error. there was a syntax error in the php script. usually web servers show the php error but apache2 and php5 showed it like that the page is not working
