DanRGleason
What 4 to 7 inch LCD screen are you using?
Fri Aug 10, 2012 12:13 am
I have the RPi setup with 1600 ma/h battery, two solar panels, BT keyboard and trackpad (2.5 in by 5 in) and it all fits in a nice box I can carry around that is just 3 in by 6 inch.
I would love to find a cheap 4 to 7 inch lcd with HDMI in, 5v USB or battery powered that I can add to my portable Pi kit.
What lcd screens have you tried? I have looked on Amazon and eBay for cheap portable TV's but the closest battery powered one I found had composite input. No hdmi inputs out there that I could locate...
Any luck from anyone else?
Bollard
Re: What 4 to 7 inch LCD screen are you using?
Fri Aug 10, 2012 11:18 am
I too am interested in this.
blc
Fri Aug 10, 2012 12:29 pm
DanRGleason wrote:I have the RPi setup with 1600 ma/h battery, two solar panels, BT keyboard and trackpad (2.5 in by 5 in) and it all fits in a nice box I can carry around that is just 3 in by 6 inch.
To be honest, I don't think I've seen screens of that size with an HDMI (or even DVI) interface; I've also looked around, and I can only find either VGA or composite... I do have a small 3.5" composite LCD, which I have a few ideas for, but it'd never be a primary monitor for my Pi; at the moment, I'm sharing the DVI connection on my main computer monitor (i.e. disconnecting one and then connecting the other!)
rpiMike
Fri Aug 10, 2012 12:40 pm
Google 'lilliput hdmi 7' not cheap but should do the job.
JeremyF
Fri Aug 10, 2012 12:44 pm
If you want to build the screen into something you could try this (12V powered): http://www.ebay.com/itm/7-TFT-INNOLUX-A ... 6rk%3D1%26
The cheapest LCD screen with HDMI in the size range you want that I could find:
http://www.ebay.com/itm/FW619AH-450-7-L ... 3f1197297a
{sig} Setup: Original version Raspberry Pi (B, rev1, 256MB), Dell 2001FP monitor (1600x1200), 8GB Class 4 SD Card with Raspbian and XBMC, DD-WRT wireless bridge
stevech
Sat Aug 11, 2012 3:52 am
most WiFi routers cannot operate as a bridge (a.k.a. Game Adapter). Cheap ones on eBay.
All WiFi routers can be re-purposed as an access point, but that's not what's needed for the Pi in this discussion.
holmez
Sat Aug 11, 2012 12:10 pm
You might want to have a look at the Screens and displays forum under Projects.
tvanbui
Thu Aug 16, 2012 2:05 am
Have you tried looking into a USB powered LCD display?
