_emanuel_
RPI3 2 GPUs?
Fri Mar 18, 2016 7:37 pm
In the IT News "golem.de" is alleged that the RPI3 2 GPU cores has. Is that correct?
Re: RPI3 2 GPUs?
Fri Mar 18, 2016 7:52 pm
_emanuel_ wrote:In the IT News "golem.de" is alleged that the RPI3 2 GPU cores has. Is that correct?
ALL Raspberry Pi's have the same VideoCore IV VPU: https://en.wikipedia.org/wiki/VideoCore
Asus ChromeBox 3 Celeron is my other computer.
jdb
Re: RPI3 2 GPUs?
Fri Mar 18, 2016 8:18 pm
Depends what you mean.
The 3D block has a set of QPUs that operate on pixel blocks with (mostly) floating-point maths. 283x has 12 of these engines.
The VPU (generic digital signal processor/RISC core that boots first and runs the firmware) is a dual-core CPU with shared 4kiB vector processing register file.
Rockets are loud.
https://astro-pi.org
_emanuel_
Re: RPI3 2 GPUs?
Fri Mar 18, 2016 8:36 pm
I got VC4 in the RPI3/2, also in some dreamboxes (bcm7XXX).
I found this on golem.de, "airpointr" Gesture Command for the Raspberry Pi, a non free SW (google translated):
By using the GPU 3D graphics performance of the Raspberry Pi is compromised when 2's model, however, the 3 Series model less because it has two graphics cores. This primarily OpenGL applications are affected. Which is important for video playback Video decoder unit but is not affected.
So I was surprised. Is there a difference between at RPI3 RPI2 (GPU).
ghans
Re: RPI3 2 GPUs?
Sat Mar 19, 2016 7:29 am
No , the GPU between model 2 and 3 has not changed.
ghans
Re: RPI3 2 GPUs?
Sat Mar 19, 2016 8:14 am
_emanuel_ wrote:I got VC4 in the RPI3/2, also in some dreamboxes (bcm7XXX).
That website is completely wrong.
mimi123
Re: RPI3 2 GPUs?
Sat Mar 19, 2016 10:15 am
It's worth noting that the VPU is at 400MHz now ;)
_emanuel_
Re: RPI3 2 GPUs?
Sat Mar 19, 2016 4:12 pm
Ok, thank you for the infos ;-)
