FAULTY PI3?
Posted: Mon Mar 07, 2016 12:36 pm
by lmoss30
Hi Guys,
i have just recieved a new PI3 from the pi hut, and noticed a component that looks wrong, C99 is this the case see photo,
will it operate like is or do i need a new board or try to repair it?
Lee
Re: FAULTY PI3?
Posted: Mon Mar 07, 2016 12:46 pm
by GTR2Fan
In relationship to your photo, C99 should be horizontal (vertical in the small image) and attached to the empty pad just to the right of it (top of it in the small image). As we have no schematics, I can't tell you whether it's safe to operate or will behave normally as it is. I'd send it back unless you're good with a soldering iron and can correct it yourself.
Why does the forum software rotate the image through 90 degrees when it's embedded? Argh!
Re: FAULTY PI3?
Posted: Mon Mar 07, 2016 1:16 pm
by 6by9
GTR2Fan wrote:Why does the forum software rotate the image through 90 degrees when it's embedded? Argh!
Being a pedant, it doesn't ;) The orientation field in the JPEG header says to rotate it 90 degrees, but for some reason when rendered as part of an HTML page that is ignored. It's displayed with the rotation if just showing the JPEG.
On the phone it comes down to the effort required to rotate the image during capture vs on render (transpose is often expensive).
Almost all modern renderers abide by the orientation field on displaying a single image - WinXP preview was the last major one I remember not doing so. But there looks to be a quirk in HTML - both Firefox and Chrome don't if part of an HTML page. Looks like this was an active discussion a while back https://bugs.chromium.org/p/chromium/is ... l?id=56845 and linked to https://bugs.webkit.org/show_bug.cgi?id=19688#c20
Re: FAULTY PI3?
Posted: Mon Mar 07, 2016 1:41 pm
by GTR2Fan
6by9 wrote:On the phone it comes down to the effort required to rotate the image during capture vs on render (transpose is often expensive).
Thanks for the explanation. Excuse me if I don't rotate my 22" monitor through 90° to correct this anomaly. It's bolted to the wall on a 3D-printed VESA mount. :lol:
Re: FAULTY PI3?
Posted: Mon Mar 07, 2016 1:48 pm
by lmoss30
Managed to remove and solder the device back on so hopefully all will work ok,
maybe one for the RP foundation to monitor if components are missplaced
Re: FAULTY PI3?
Posted: Mon Mar 07, 2016 1:51 pm
by jdb
Automated optical inspection should make this an impossibility.
Can you post the serial number from /proc/cpuinfo please?
Re: FAULTY PI3?
Posted: Mon Mar 07, 2016 4:03 pm
by lmoss30
No problem i will once i get home this evening and get some power on the board,
It seems to be running now so hopefully a little bit of soldering has fixed it.
Re: FAULTY PI3?
Posted: Mon Mar 07, 2016 8:42 pm
by lmoss30
Hi jdb,
How do I run /proc/cpuinfo, if I type this into command line it says permission denied,
Re: FAULTY PI3?
Posted: Mon Mar 07, 2016 8:53 pm
by ait
cat /proc/cpuinfo
or
sudo cat /proc/cpuinfo
Re: FAULTY PI3?
Posted: Mon Mar 07, 2016 8:57 pm
by lmoss30
processor : 0
model name : ARMv7 Processor rev 4 (v7l)
BogoMIPS : 38.40
Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm crc32
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 1
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 2
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 3
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
Hardware : BCM2709
Revision : a02082
Serial : 00000000d3795bc5
Re: FAULTY PI3?
Posted: Wed Mar 09, 2016 5:07 pm
by jdb
Thanks.
