KeithSloan
Trying to read values via I2C
Mon Mar 07, 2016 11:01 am
I am having problems reading values via I2C from an Arduino nano slave.
Whilst testing I have the I2C slave put out constant values, but what the Pi reads do not agree with those constant values sometimes it read 9 instead of 19 ( 0x13) I put in sleeps of 1 second between register reads which helped but did not resolve the problem
Running the code - note when it reads 9 instead of 19
python readReg.py
19
20
1234
19
20
1234
9
20
1234
9
20
1234
9
20
The code
import smbus
import time
bus = smbus.SMBus(1)
address = 25
def write(value):
        bus.write_byte_data(address, 0, value)
        return -1
def read_AN2():
        an2 = bus.read_word_data(address, 2)
        return an2
def read_AN3():
        an3 = bus.read_word_data(address, 3)
        return an3
def read_ID0():
        id = bus.read_byte_data(address, 0)
        return id
def read_ID1():
        id = bus.read_byte_data(address, 1)
        return id
while True:
      print read_ID0()
      time.sleep(1)
      print read_ID1()
      time.sleep(1)
      print format(read_AN2(),'04x')
      time.sleep(1)
The I2C slave code
// Simple I2C protocol for Arduino
// Slave side program
// (c) 2014 Ignas Gramba
#include <Wire.h>
#define XSensorPin 2
#define YSensorPin 3
const byte SlaveDeviceId = 25;
byte Register = 0;
void setup(){
  Wire.begin(SlaveDeviceId);      // join i2c bus with Slave ID
  Wire.onReceive(receiveCommand); // register talk event
  Wire.onRequest(slavesRespond);  // register callback event
  pinMode(XSensorPin, INPUT);
  pinMode(YSensorPin, INPUT);
void loop(){
  delay(100);
void receiveCommand(int howMany){
  Register = Wire.read(); // 1 byte (maximum 256 commands)
void slavesRespond(){
  int returnValue = 0x12;
  //Wire.write(returnValue+Register);
  //return;
  int buffer1;
  switch(Register){
    case 0:   // No new command was received
      //Wire.write("NA");
      Wire.write(0x13);
    break;
    case 1:
      Wire.write(0x14);
      break;
    case 2:   // Return X sensor value
      //returnValue = GetXSensorValue();
      buffer1 = 0x1234;
      Wire.write((char *) &buffer1,2);
    break;
    case 3:   // Return Y sensor value
      //returnValue = GetYSensorValue();
      returnValue = 0x0500;
    break;
  return;
  returnValue = Register;
  byte buffer[2];                 // split int value into two bytes buffer
  buffer[0] = returnValue >> 8;
  buffer[1] = returnValue & 255;
  //buffer[0] = 6;
  //buffer[1] = 0;
  Wire.write((char * ) buffer, 2);          // return response to last command
  Register = 0;          // null last Master's command
int GetXSensorValue(){
  int val = analogRead(XSensorPin);
  return val;
int GetYSensorValue(){
  int val = analogRead(YSensorPin);
  return val;
