Connecting a floppy drive to my machine.
Posted: Fri Mar 04, 2016 10:57 pm
by EroEdellabrina
Hello, i'm working on making an NES emulator that reads games from floppy disks. I am okay with the OS, but i can't figure out how to connect a 34 pin floppy drive to the raspberry pi. If someone can help me i'll be glad, thank you.
Re: Connecting a floppy drive to my machine.
Posted: Sat Mar 05, 2016 12:40 am
by klricks
There is no feasible way to get a floppy drive working on a RPi by direct connection. Even if you could make the electrical connection nothing would happen without extensive programming of drivers etc.
Your only option would be to get a USB floppy drive but I have no idea if there is one that will work on the RPi?
Also many years ago I tried loading some old floppies and none of them would work. The magnetic recording on the disk weakens over time making the disks unusable.
Posted: Sat Mar 05, 2016 1:04 am
by asandford
EroEdellabrina wrote:Hello, i'm working on making an NES emulator that reads games from floppy disks. I am okay with the OS, but i can't figure out how to connect a 34 pin floppy drive to the raspberry pi. If someone can help me i'll be glad, thank you.
Only the even pins carry a signal, the odd pins are ground. Someone has done an Arduino floppy controller.
Posted: Sat Mar 05, 2016 1:09 am
by stubright
As klricks said a USB floppy would probably be your best bet. I just tested a Dell one and I could mount it using gnome-disk-utility under Raspbian.
How easy it would be to mount in an emulator is anyone's guess, how reliable, again anyone's guess.
The floppy drive I used was a Dell fddm-101. I'm sure they'll be on fleabay.
It's an old laptop one, interchangeable with a cdrom (with a usb connector on the side).
https://ixquick-proxy.com/do/show_pictu ... 70c6d30662
Stu
Posted: Sat Mar 05, 2016 7:57 am
by hansotten
USB floppy drives work fine on a Raspberry, I have got a Freecom type, that just works with standard FAT formatted floppies.
What you will not get to work with USB is low level access, dumping tracks etc to overcome non-standard formatting. For those tools you will need a standard PC floppy interface, 765 IC based for example. Not available afaik for a Raspberry.
Or you could look at virtual floppy drives like the Catweasel (See a blog article on Adafruit).
Posted: Fri Apr 03, 2020 2:13 pm
by Lukis142
On ebay you can get 34 pin to USB converters and they cost around 14 dollars, but you have to get some power and an old working floppy drive.
Posted: Fri Apr 03, 2020 10:22 pm
by drgeoff
On ebay you can get a new cased USB floppy drive for less than £9.
