AndyNC
Moving from Pi 2 to 3 using same image
Thu Mar 03, 2016 12:40 pm
I've just got my Pi 2 in a good state running various data collection apps, SQLite3, Apache etc and am think of up grading to the Pi 3.
I'm running the system from an external Hard drive and booting from an SD card.
I would like to upgrade the Pi2 to 3 without having to re-install all the apps, compilers etc and recompile my apps.
Is it possible to change the Pi2 to Pi3 buy just doing and apt-get update/upgrade and changing the hardware.?
Cheers
Andy
RaTTuS
Contact: Twitter YouTube
Re: Moving from Pi 2 to 3 using same image
Thu Mar 03, 2016 12:45 pm
are you in jessie or wheezy ?
but
sudo apt-get update && sudo apt-get dist-upgrade
is a good start
making backups before you move will obviously be wise.
it should work for jessie - wheezy less likely
Covfefe
AndyNC
Thu Mar 03, 2016 12:46 pm
thanks,
$ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
NAME="Raspbian GNU/Linux"
VERSION_ID="8"
VERSION="8 (jessie)"
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
So probably OK
Cheers
Andy
Thu Mar 03, 2016 1:11 pm
AndyNC wrote:thanks,
VERSION_ID="8"
ID=raspbian
ID_LIKE=debian
So probably OK
Cheers
Andy
The MagPi 43 discusses upgrading Raspbian Jessie for RPi 3B readiness ;)
Thinking outside the box is better than burying your head in the sand...
AndyNC
Thu Mar 03, 2016 1:16 pm
Many thanks, I'll read it a bit later.
Cheers
Andy
Fidelius
Thu Mar 03, 2016 2:04 pm
RaTTuS wrote:sudo apt-get update && sudo apt-get dist-upgrade
This also works with Ubuntu Mate for the Pi, plus a
sudo rpi-update
... because this way Ubuntu for the Pi fetches the Foundation's newest Raspbian kernel + firmware.
In the end you can happily exchange the µSD-card between the Pi2 and Pi3. That's great, and the Foundation did a good job in keeping the compatibility.
