Rive
Re: RPi 3 SoC at nearly 100 °C, reporting 80 °C
Wed Apr 27, 2016 2:28 pm
loadbang wrote:For all those running stress tests and measuring CPU speed, make sure you are running to get your speed:
# vcgencmd measure_clock arm | sed -e "s/frequency(45)=//g"
rather than;
# cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq
First one shows the actual CPU frequency, the other is what the governor sets.
These are better:
while true; do vcgencmd measure_temp && vcgencmd measure_clock arm; sleep 10; done
watch '(vcgencmd measure_temp; vcgencmd measure_clock arm)'
DNPNWO
loadbang
Thu Apr 28, 2016 2:02 pm
Cheers Rive.
I have also forked RPi Monitor with a slight modification. Main page shows actual CPU frequency as well. https://github.com/simonhowes/RPi-Monitor
Change: https://github.com/simonhowes/RPi-Monit ... e/cpu.conf
Here is my 3 live: http://simonhowes.suroot.com:8888/
Rive
Thu Apr 28, 2016 2:32 pm
loadbang wrote:Cheers Rive.
I use the built in monitors to keep an eye on everything during normal usage.
thermals...cpu freq...cpu usage
right click to enlarge (open image), see taskbar bottom right hand corner near clock:
DNPNWO
loadbang
Thu Apr 28, 2016 4:00 pm
I run everything headless. :)
Rive
Sat Apr 30, 2016 6:59 pm
loadbang wrote:https://simonhowes.files.wordpress.com/ ... g_1409.jpg
A 17mm fan in Maplins in the UK.
Better?
DNPNWO
loadbang
Sat Apr 30, 2016 7:27 pm
I'm thinking one that will fit in a case.
Rive
Sat Apr 30, 2016 7:49 pm
loadbang wrote:I'm thinking one that will fit in a case.
On a case works for me too. That fan shown above can easily be fit into the "white' top" part of the official pi3 case (after you use a hole saw on it anyways). I was tempted to do just that that, (but decided on a velcro'd 70mm x10mm fan on top instead). And we already know that black aluminum heatsink fits the SoC quite nicely. 8-)
These are my "spare' parts, that I will probably never do anything with, and they will just sit in a drawer until I decide to play with them. The more I think about it, the more i think I may try the hole saw idea, and fit that fan into the top of the official case.
DNPNWO
JohnSmith41
Fri May 06, 2016 5:05 am
I'm probably doing something really wrong, but my Pi 3 is running the PiRate Box distro, and every so often while it is sitting on my desk, I will notice the WiFi network is gone, and when I go to check the Pi, it is burning to the touch. Unplugging it and plugging it back in seems to solve the problem, but it has two heatsinks on it, so it shouldn't be getting that hot, right? Am I doing something wrong here?
My former home is at http://www.smwcentral.net/ and that is where you can PM me if you need to
ShiftPlusOne
Fri May 06, 2016 4:15 pm
JohnSmith41 wrote:I'm probably doing something really wrong, but my Pi 3 is running the PiRate Box distro, and every so often while it is sitting on my desk, I will notice the WiFi network is gone, and when I go to check the Pi, it is burning to the touch. Unplugging it and plugging it back in seems to solve the problem, but it has two heatsinks on it, so it shouldn't be getting that hot, right? Am I doing something wrong here?
Touch isn't a good way to check the temperature. What does vcgencmd measure_temp report?
JohnSmith41
Fri May 06, 2016 7:54 pm
The problem is, I have no way to check what vcgencmd measure_temp says, as the Pi 3 shuts off at this point. When it happens again, I will restart the Pi and run the command as quick as I can
rurwin
Fri May 06, 2016 10:11 pm
JohnSmith41 wrote:The problem is, I have no way to check what vcgencmd measure_temp says, as the Pi 3 shuts off at this point. When it happens again, I will restart the Pi and run the command as quick as I can
Just have a background task append the current temperature to a text file every 15 seconds. About 100 bytes per minute, 6k per hour,150k per day; plenty of room to grow for years. And when it goes wrong you'll have a record of how the temperature was behaving up until it crashed.
JohnSmith41
Wed Jun 15, 2016 5:50 am
I don't mean to dig up a thread, but my Pi 3 is resting at 83.8C, with a heatsink, while under heavy load. My Pi 2 is resting at 67.0C with a heatsink, while under heavy load, and it is running FASTER than the Pi 3. Is my Pi 3 defective?
gkreidl
Wed Jun 15, 2016 8:04 am
JohnSmith41 wrote: I don't mean to dig up a thread, but my Pi 3 is resting at 83.8C, with a heatsink, while under heavy load. My Pi 2 is resting at 67.0C with a heatsink, while under heavy load, and it is running FASTER than the Pi 3. Is my Pi 3 defective?
No, it's throttling down (check the CPU frequency).
A heat sink without a good airflow is rather useless, especially in these almost completely closed cheap plastic boxes.
Take the lid off or get a Flirc case or a case with open sides or add a fan.
Minimal Kiosk Browser (kweb)
JohnSmith41
Wed Jun 15, 2016 8:50 am
I have both my Pi 2 and 3 sitting out without a case (I am aware of the dangers of that, including shorting and static) behind my TV. I will be putting a fan on my Pi 3. Also, thanks for letting me know about the throttling, I almost forgot that it did that!
Slackware
Sun Jun 19, 2016 11:05 pm
Maybe the excess heat is from the 32bits just sitting there. Once it goes 64bit they will flow instead of sitting there getting hot.
Slackware
Sun Jun 19, 2016 11:12 pm
loadbang wrote:I run everything headless. :)
sounds like the perfect setup for a HEADS UP display then.
Cavecraft
Sat Jul 02, 2016 9:01 am
allfox wrote:Agreed~ But maybe with Pi 3, everyone would need a colding solution.It would be ready to boil coffee in 5 min. Edited: This joke is bad, as it makes people think something would go wrong at 100 C. I did think so, however follow threads from moderators explained that there is nothing hazard. It's hot, but that's all of it.
I don't like colding fans, they are noisy.
They don't have true, the SoC contains silicum and that melts/breaks at around 85 degrees Celcius!
mahjongg
Sat Jul 02, 2016 2:23 pm
bullpoop! the melting point of silicon is actually 1414 °C :lol:
as for "going wrong", I assume you mean the FET's in the SoC stop working at the speed needed, 85 °C is far from the temperature that would happen too, the SoC was tested in an oven at far higher temperatures than that.
ejolson
Sat Jul 02, 2016 11:43 pm
mahjongg wrote:as for "going wrong", I assume you mean the FET's in the SoC stop working at the speed needed
Given the $35 price, the most significant thing that could go wrong is starting a fire and burning down the house. Maybe don't place a Pi 3 on the table under a bunch of newspapers and everything will be fine.
Cavecraft
Sun Jul 03, 2016 9:43 am
bullshit! the melting point of silicon is actually 1414 °C :lol:
Lol the temperature will decrease in less then 1 minute when you put a cup of coffee on it.
dom
Sun Jul 03, 2016 11:31 am
ejolson wrote:Given the $35 price, the most significant thing that could go wrong is starting a fire and burning down the house. Maybe don't place a Pi 3 on the table under a bunch of newspapers and everything will be fine.
The auto ignition point of paper is somewhere near 451'F (233'C), so you are not going to ignite newspaper from a Pi.
dpotop
Sat Sep 10, 2016 1:22 pm
Small contribution to this thread: I also noticed a discrepancy between actual and measured temperature, but only after installing a heat sink on the SoC. Here's how it worked:
- At first, I used my RPi3 without a heat sink. During heavy loads (e.g. compilation) temperature went to 80C and then stabilized with +/-1 degree variations (the expected behavior). When temperature increased, frequency would go down, and the reverse.
- Once I installed the heat sink (aluminium, taken from the chipset of an old PC motherboard) the temperature stabilized around 70 degrees, and there was some throttling.
So I'm guessing that there are 2 temperature sensors:
- One is used by the CPU to detect overheating and to throttle. I would be curious to know the cut-off temperature.
- The second is somewhere else in the SoC casing, and it can be read in software.
When adding a heat sink, the temperature gradient changes.
Let me know if you have more info on this.
Best,
Dumitru
dpotop
ejolson
Sat Sep 10, 2016 8:12 pm
dpotop wrote:Small contribution to this thread: I also noticed a discrepancy between actual and measured temperature, but only after installing a heat sink on the SoC. Here's how it worked:
Best,
Dumitru
Are you measuring temperature with an external sensor or probe of some sort?
DavidS
Sat Sep 10, 2016 8:31 pm
This seems to negate one of the major advantages of using an ARM. That is the fact that the ARM always runs cool.
If it is really getting over 50 degrees C, then it should be rated to run at what ever clock it keeps down under 50 degrees C with a 100% load for an extended time on all 4 ARM cores.
running an RPi 2B at 1100MHz (1.1GHz) for a long time, and often doing things that push all of the ARM cores at 100% for hours at a time, I have never had the tempurature exceed 49 degrees C.
RPi = The best ARM based RISC OS computer around
More than 95% of posts made from RISC OS on RPi 1B/1B+ computers. Most of the rest from RISC OS on RPi 2B/3B/3B+ computers
