ItsMurf
Best WIFI Dongle
Mon Feb 29, 2016 2:09 am
Hello, I am currently using my Pi in a room that does not have "full" access to a Ethernet port.
I was wondering what the best WIFI dongle would be.
The room is about 30 ft. away from the router.
The router supports 5ghz however that is not needed. :mrgreen:
Much Pi Very Program.
-Murf
anand1
Contact: Website Yahoo Messenger
Re: Best WIFI Dongle
Mon Feb 29, 2016 2:40 am
I have been using leoxsys WiFi USB dongle bought from ebay its very cheap almost less than 3 bucks or so.......its working fine after minor tweaking to install the driver in my Raspbian Jessie.....
ItsMurf
Mon Feb 29, 2016 2:46 am
Sounds good. Thanks.
Any other idea's?
Is it even worth it to get an expensive one?
-Murf
Mon Feb 29, 2016 9:54 am
Buy the cheapest WiFi dongle you can find on eBay. They mostly work, most of the time straight out of the box. It's only the rtl8188eu dongles that are a pain in the tail.
The best is the official RPF dongle: https://www.raspberrypi.org/products/usb-wifi-dongle/ although you may have a struggle running that with Win10IoT.
This is a doctor free zone.
ghodan
Mon Feb 29, 2016 10:02 am
If you want THE best wifi adapter in your pi, then i could recommend these 2:
TP-LINK TL-WN722N
Alfa Network AWUS036NEH
Bot have external antenna that are a few inch long, and because of that they easily beat all the nano wifi adapters with their build in mini antenna.
The antenna can also be replaced with a larger one like 8db or 9db.
Also nice for indoor to a specific area or extreme outdoor range: You can plugin a panel antenna.
Also the AWUS036NEH can do 1000MW power... i dont know if that is allowed in your country...
And both do packet injection in Kali Linux if you are into that stuff.
Update:
The internal antenna of the Wipi v2 is big for a small wifi adaptor:
http://raspi.tv/2015/new-official-raspb ... and-edimax
davidcoton
Mon Feb 29, 2016 9:09 pm
ghodan wrote: Also the AWUS036NEH can do 1000MW power...
That could solve the world energy crisis, if it still runs from a 5V 2A supply.
Signature retired
ghodan
Tue Mar 01, 2016 6:34 am
:oops: Oops... that will not work eh? :oops:
This one work for sure: TP-LINK TL-WN722N
Its my main wifi adapter for my current Pi2
allfox
Tue Mar 01, 2016 7:51 am
I had a TP LINK TL-WN722N before, I dropped it when I know its firmware could only support 7 stations in AP mode. I quite regret that as those dongles seem no longer available in China.
It uses ath9k_htc driver so works OOTB in both station mode and AP mode. Unlike most TP LINK products, this dongle's new version do not change the chip, means it always have a good driver.
It has a big antenna, and changeable.
It has 1 transmitter, 2 receivers, so more powerful than most 150M dongle. Even that one on Pi 3 is a 1 transmitter 1 receiver device.
The thing which makes me made the wrong decision is it could only support 7 stations in AP mode.
Currently, I'm using a TP LINK TL-WN822N. Its newest version is using Realtek 8192EU chip. So there is no driver in Raspbian. Thanks to MrEngman who provides a workaround for this.
davidcoton
Tue Mar 01, 2016 9:34 am
Sorry, my comment should have been marked :lol:
I think you meant 1000mW (1W), not 1000MW (1000000000W), the output of a big power station.
I don't know whether it will work legally or with the supplied drivers, but to use 1W RF output you will need a good power supply.
Signature retired
dobra-dobra
Tue Mar 01, 2016 1:30 pm
I can recommend the following two dongles:
1) http://www.ebay.com/itm/WiFi-300Mbps-US ... SweW5VY8tW
2) http://www.ebay.com/itm/Protronix-Mini- ... SwDuJWxgcj
Pick the one with antenna when you plan to use your Pi far from the router.
And do not buy this one:
http://www.ebay.com/itm/262217166401?_t ... EBIDX%3AIT
It's the cheapest one on eBay, but it heats a lot and connection is not stable.
Look for better offers, these are only for example.
mutley
Tue Mar 01, 2016 3:14 pm
EDI Max AC600 is what I would recommend as the best I have tested so far. Super fast, very reliable and very little packet loss. It supports both 5 and 2.4 Ghz on the Pi and uses the 8812au chipset. On 5Ghz it gives me better performance than the built in SMSC95xx Ethernet adapter on a Pi 2.
http://www.edimax.com/edimax/merchandis ... w-7811uac/
It is not supported natively though, but since it's 8812au chipset there are pre-compiled drivers all over the place for it. This is the thread where I got the driver from
viewtopic.php?f=28&t=102323&p=782878
ric96
Tue Mar 01, 2016 3:22 pm
Pi3 :D
My apologies for shameless YouTube Plugs...
youtube.com/sahajsarup
twitter @sahajsarup
skype srics1996
e-mail: [email protected]
Blog: http://www.geektillithertz.com/wordpress
Web: http://www.geektillithertz.com
ItsMurf
Thu Mar 03, 2016 11:13 pm
ghodan wrote:If you want THE best wifi adapter in your pi, then i could recommend these 2:
TP-LINK TL-WN722N
Update:
I think I will go with the TP-LINK or maybe the official Pi one.
-Murf
gychang
Thu Mar 30, 2017 3:07 am
I have been using leoxsys WiFi USB dongle bought from ebay its very cheap almost less than 3 bucks or so.......its working fine after minor tweaking to install the driver in my Raspbian Jessie.....[/quote]
what do u mean by "minor tweaking"?? :P
gychang
Thu Mar 30, 2017 3:23 am
mutley wrote:EDI Max AC600 is what I would recommend as the best I have tested so far. Super fast, very reliable and very little packet loss. It supports both 5 and 2.4 Ghz on the Pi and uses the 8812au chipset. On 5Ghz it gives me better performance than the built in SMSC95xx Ethernet adapter on a Pi 2.
this seem ideal for me since I have AC router, but never having compiled scares me a bit, will assume it also works in ubuntu variants?
NickT
Thu Mar 30, 2017 4:47 am
My main criterion for selecting a dongle is price, rather than performance, so I have gone for cheap e-bay items. The search term I used was RTL8188CUS . These have come from the far east and cost less than £2. They have always worked out of the box for me.
