I was wondering what the best WIFI dongle would be.
The room is about 30 ft. away from the router.
The router supports 5ghz however that is not needed.
I have been using leoxsys WiFi USB dongle bought from ebay its very cheap almost less than 3 bucks or so.......its working fine after minor tweaking to install the driver in my Raspbian Jessie.....I was wondering what the best WIFI dongle would be.
Sounds good. Thanks.anand1 wrote:I have been using leoxsys WiFi USB dongle bought from ebay its very cheap almost less than 3 bucks or so.......its working fine after minor tweaking to install the driver in my Raspbian Jessie.....I was wondering what the best WIFI dongle would be.
That could solve the world energy crisis, if it still runs from a 5V 2A supply.ghodan wrote: Also the AWUS036NEH can do 1000MW power...
davidcoton wrote:That could solve the world energy crisis, if it still runs from a 5V 2A supply.ghodan wrote: Also the AWUS036NEH can do 1000MW power...
Sorry, my comment should have been markedghodan wrote:davidcoton wrote:That could solve the world energy crisis, if it still runs from a 5V 2A supply.ghodan wrote: Also the AWUS036NEH can do 1000MW power...Oops... that will not work eh?
This one work for sure: TP-LINK TL-WN722N
Its my main wifi adapter for my current Pi2
ghodan wrote:If you want THE best wifi adapter in your pi, then i could recommend these 2:
TP-LINK TL-WN722N
Alfa Network AWUS036NEH
Bot have external antenna that are a few inch long, and because of that they easily beat all the nano wifi adapters with their build in mini antenna.
The antenna can also be replaced with a larger one like 8db or 9db.
Also nice for indoor to a specific area or extreme outdoor range: You can plugin a panel antenna.
Also the AWUS036NEH can do 1000MW power... i dont know if that is allowed in your country...
And both do packet injection in Kali Linux if you are into that stuff.
Update:
The internal antenna of the Wipi v2 is big for a small wifi adaptor:
http://raspi.tv/2015/new-official-raspb ... and-edimax
this seem ideal for me since I have AC router, but never having compiled scares me a bit, will assume it also works in ubuntu variants?mutley wrote:EDI Max AC600 is what I would recommend as the best I have tested so far. Super fast, very reliable and very little packet loss. It supports both 5 and 2.4 Ghz on the Pi and uses the 8812au chipset. On 5Ghz it gives me better performance than the built in SMSC95xx Ethernet adapter on a Pi 2.
http://www.edimax.com/edimax/merchandis ... w-7811uac/
It is not supported natively though, but since it's 8812au chipset there are pre-compiled drivers all over the place for it. This is the thread where I got the driver from
viewtopic.php?f=28&t=102323&p=782878
