When i start rpi the temperature of cpu will increase rapidly (less than 2 seconds),
and the rpi can also work ,but a little slow,
How does this happen?
Is there anything wrong with the hardware?
how to repair it?
RaTTuS wrote:what have you plugged into your RPI on the GPIO ?
RPI's are not repairable
you possibly have shorted or overloaded the GPIO and have caused permanent damage
i have a simple temperature detection device , when the rpi start , the temperature will increase to 68 in 2 secShiftPlusOne wrote:How have you determined that it's overheating? What's the measured temperature?
It is better to measure the internal temperature with the command vcgencmd measure_tempkscorpio wrote:i have a simple temperature detection device
rpdom@raspi4:~$ vcgencmd measure_temp
temp=21.3'C
Fan? What fan? Why would there be a fan?dhada wrote:The reason behind the over heatind may be slow speed of fan or sometimes your fan stops.... you should check when computer starts..
Do you have a multimeter and know how to check voltages? If so, does the sim card module feed power into the Pi? If so, how much?kscorpio wrote:i have a sim card moudle and an usb to ttl card , but the sim card moudle has individual power supply,
68°F isn't a problem. 68°C may show that there's something wrong and the magic smoke is due to make a bid for freedom.kscorpio wrote:i have a simple temperature detection device , when the rpi start , the temperature will increase to 68 in 2 secShiftPlusOne wrote:How have you determined that it's overheating? What's the measured temperature?
It wouldn't be a problem, but it would be a bleedin' miracle unless it's sitting inside a fridge freezer box!DougieLawson wrote:68°F isn't a problem.
GTR2Fan wrote:It wouldn't be a problem, but it would be a bleedin' miracle unless it's sitting inside a fridge freezer box!DougieLawson wrote:68°F isn't a problem.
Isn't far off 68Frpdom wrote: rpdom@raspi4:~$ vcgencmd measure_temp
temp=21.3'C
Wow! Where's that one? None of the 5 Pi I've played with so far have idled any lower than 20°C above ambient on standard clocks and uncased.asandford wrote:Isn't far off 68F
rpdom appears to be in Essex.GTR2Fan wrote:Wow! Where's that one? None of the 5 Pi I've played with so far have idled any lower than 20°C above ambient on standard clocks and uncased.asandford wrote:Isn't far off 68F
That's correct.asandford wrote:rpdom appears to be in Essex.
