RPI2 Into Wireless Router Config Script
Posted: Tue Feb 23, 2016 1:59 am
by cannonfodder728
Since, Ive borrowed and learned a lot from these forums, I thought I might share my very crude config script that Ive used to configure my RPI2 into a wireless router. The only requirement is working wired and wireless NICs. Please modify and use as you deem appropriate.
#!/bin/bash
#List Network Interfaces and input wired and wireless nic device names
echo "The following interfaces were found on your Pi"
ifconfig -a | sed 's/[ \t].*//;/^$/d'
echo "Enter Wired interface which will be connected to Internet"
read wired_nic
echo "Enter WLAN interface which will be used for AP"
read wlan_nic
now=$(date +"%m_%d_%Y_%H_%M_%S")
#Configure Interfaces file
echo "Configure Interfaces? (Enter 1 or 2 or any other key to skip)"
echo "1) Yes"
echo "2) No"
read input
if [ $input = "1" ];
then
interfaces_file='/etc/network/interfaces'
sudo cp $interfaces_file /etc/network/interfaces$now
sudo rm $interfaces_file
sudo rm -f $interfaces_file
echo "auto lo\n">>$interfaces_file
echo "iface lo inet loopback\n\n">>$interfaces_file
fi
#configure wireless nic appropriately
echo "How will wireless connection be configured? (Note: Hostapd entry will point to /etc/hostapd/hostapd.conf) (Enter 1 or 2 or any other key to skip)"
echo "1) Static"
echo "2) DHCP"
read input
then
echo "Config WLAN using Static"
echo "Enter Static IP Address for WLAN"
read wlanstaticip
echo "Enter Netmask for WLAN"
read wlannetmask
echo "auto $wlan_nic">>$interfaces_file
echo "allow-hotplug $wlan_nic">>$interfaces_file
echo "iface $wlan_nic inet static">>$interfaces_file
echo "hostapd /etc/hostapd/hostapd.conf">>$interfaces_file
echo "address $wlanstaticip">>$interfaces_file
echo "netmask $wlannetmask">>$interfaces_file
fi
if [ $input = "2" ];
then
echo "Config WLAN using DHCP"
echo -e "auto $wlan_nic\n">>$interfaces_file
echo -e "iface $wlan_nic inet dhcp\n">>$interfaces_file
fi
#configure wired nic appropriately
echo "How will wired connection be configured? (Enter 1 or 2 or any other key to skip)"
echo "1) Static"
echo "2) DHCP"
read input
then
echo "Config Wired using static"
echo "Enter Static IP Address"
read wiredstaticip
echo "Enter Netmask"
read wirednetmask
echo "Enter Gateway"
read wiredgateway
echo "Enter DNS Server"
read wireddnsserver
echo "auto $wired_nic">>$interfaces_file
echo "iface $wired_nic inet static\n">>$interfaces_file
echo "address $wiredstaticip\n">>$interfaces_file
echo "netmask $wirednetmask\n">>$interfaces_file
echo "gateway $wiredgateway\n">>$interfaces_file
echo "dns-nameservers $wireddnsserver\n">>$interfaces_file
fi
then
echo "Config wired using DHCP"
echo "auto $wired_nic\n">>$interfaces_file
echo "iface $wired_nic inet dhcp\n">>$interfaces_file
fi
#install hostapd
echo "Configure Wireless connection? (Enter 1 or 2 or any other key to skip)"
echo "1) Yes"
echo "2) No"
read input
then
lsusb
echo "The usb devices above were detected, is your device a Realtek chip based device? (Enter 1 or 2)"
echo "1) Yes"
echo "2) No"
read isRealTek
echo "Please enter what you would like your SSID to be?"
read SSID
echo "Please enter what you desired WLAN password?"
read wifipass
hostapdconffile='/etc/hostapd/hostapd.conf'
if [ $isRealTek = "1" ];
then
#download and install Realtek hostapd
sudo apt-get autoremove hostapd
sudo wget https://github.com/jenssegers/RTL8188-h ... 2.0.tar.gz
tar -zxvf v2.0.tar.gz
cd RTL8188-hostapd-2.0/hostapd
sudo make
sudo make install
sudo cp $hostapdconffile /etc/hostapd/hostapd$now
sudo rm -f $hostapdconffile
# WPA and WPA2 configuration
sudo echo "# Basic configuration">>$hostapdconffile
sudo echo "interface=$wlan_nic">>$hostapdconffile
sudo echo "ssid=$SSID">>$hostapdconffile
sudo echo "channel=1">>$hostapdconffile
sudo echo "# WPA and WPA2 configuration">>$hostapdconffile
sudo echo "macaddr_acl=0">>$hostapdconffile
sudo echo "auth_algs=1">>$hostapdconffile
sudo echo "ignore_broadcast_ssid=0">>$hostapdconffile
sudo echo "wpa=3">>$hostapdconffile
sudo echo "wpa_passphrase=$wifipass">>$hostapdconffile
sudo echo "wpa_key_mgmt=WPA-PSK">>$hostapdconffile
sudo echo "wpa_pairwise=TKIP">>$hostapdconffile
sudo echo "rsn_pairwise=CCMP">>$hostapdconffile
sudo echo "# Hardware configuration">>$hostapdconffile
sudo echo "driver=rtl871xdrv">>$hostapdconffile
sudo echo "ieee80211n=1">>$hostapdconffile
sudo echo "hw_mode=g">>$hostapdconffile
sudo echo "device_name=RTL8192CU">>$hostapdconffile
sudo echo "manufacturer=Realtek">>$hostapdconffile
sudo update-rc.d hostapd defaults
sudo update-rc.d hostapd enable
sudo service hostapd start
echo "Done configuring hostapd.conf file"
fi
if [ $isRealTek = "2" ];
then
#download and install regular hostapd
sudo apt-get install hostapd
sudo echo "driver=nl80211">>$hostapdconffile
fi
fi
#configure DHCP Server
echo "Configure DHCP Server? (Enter 1 or 2 or any other key to skip)"
echo "1) Yes"
echo "2) No"
read input
then
echo "Please enter DHCP Server subnet (usually subnet for WLAN NIC)"
read subnet
echo "Please enter starting IP of DHCP range"
read startip
echo "Please enter ending IP of DHCP range"
read endip
echo "Please broadcast IP"
read broadcastip
echo "Installing DHCP Server for DHCP and DNS Services on WLAN"
sudo apt-get install isc-dhcp-server
dhcpconffile='/etc/dhcp/dhcpd.conf'
sudo cp $dhcpconffile /etc/dhcp/dhcpd.conf.$now
sudo rm -f $dhcpconffile
sudo echo "subnet $subnet netmask 255.255.255.0">>$dhcpconffile
sudo echo "{">>$dhcpconffile
sudo echo "range $startip $endip;">>$dhcpconffile
sudo echo "option broadcast-address $broadcastip;">>$dhcpconffile
sudo echo "option routers $wlanstaticip;">>$dhcpconffile
sudo echo "default-lease-time 600;">>$dhcpconffile
sudo echo "max-lease-time 7200;">>$dhcpconffile
sudo echo "option domain-name-servers 8.8.8.8, 8.8.4.4;">>$dhcpconffile
sudo echo "}">>$dhcpconffile
sudo echo "authoritative;">>$dhcpconffile
sudo cp /etc/default/isc-dhcp-server /etc/default/isc-dhcp-server$now
sudo rm -f /etc/default/isc-dhcp-server
sudo echo "INTERFACES=$wlan_nic">>/etc/default/isc-dhcp-server
sudo update-rc.d isc-dhcp-server enable
sudo service isc-dhcp-server start
fi
#Configure sshd including new port
echo "Would you like to change default SSH port?"
echo "1) Yes"
echo "2) No"
read changesshport
if [ $changesshport = "1" ]; then
echo "Please enter on which port you would like SSH Server to listen?"
read sshport
sudo sed -i 's/Port 22/Port '$sshport'/g' /etc/ssh/sshd_config
#echo "Port $sshport">>/etc/ssh/sshd_config
echo "Changed SSH Port"
fi
#install samba
smbconffile='/etc/samba/smb.conf'
echo "Would you like to install Samba Server?"
echo "1) Yes"
echo "2) No"
read samba
if [ $samba = "1" ];
then
echo "Installing ExFat support"
sudo apt-get install exfat-utils -y
sudo apt-get install samba samba-common-bin
echo "Please enter path to folder you would like to share (ie path to folder where external drive is mounted)"
read sambashare
sudo cp $smbconffile /etc/samba/smb.conf$now
sudo rm -f $smbconffile
sudo echo "[global]">> $smbconffile
sudo echo "interfaces = $wlan_nic lo">> $smbconffile
sudo echo "bind interfaces only = yes">> $smbconffile
sudo echo "dns proxy = no">> $smbconffile
sudo echo "[share]">> $smbconffile
sudo echo "comment= Pi Home">> $smbconffile
sudo echo "path=$sambashare">> $smbconffile
sudo echo "guest ok = yes">> $smbconffile
sudo echo "create mask = 0777">> $smbconffile
sudo echo "comment = Backup drive">> $smbconffile
sudo echo "directory mask = 0777">> $smbconffile
sudo echo "browseable = yes">> $smbconffile
sudo echo "writable = yes">> $smbconffile
sudo echo "public=yes">>$smbconffile
sudo echo "force user = root">> $smbconffile
sudo echo "force group = root">> $smbconffile
sudo echo "log file = /var/log/samba/log.%m">> $smbconffile
sudo echo "max log size = 1000">> $smbconffile
sudo echo "syslog = 0">> $smbconffile
sudo echo "panic action = /usr/share/samba/panic-action %d">> $smbconffile
sudo echo "server role = standalone server">> $smbconffile
sudo echo "passdb backend = tdbsam">> $smbconffile
sudo echo "obey pam restrictions = yes">> $smbconffile
sudo echo "unix password sync = yes">> $smbconffile
sudo echo "passwd program = /usr/bin/passwd %u">> $smbconffile
sudo echo "passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully*\n">> $smbconffile
sudo echo "pam password change = yes">> $smbconffile
sudo echo "map to guest = bad user">> $smbconffile
sudo smbpasswd -a pi
sudo echo "Done setting up samba"
fi
#configure firewall
echo "Configure Firewall? (Enter 1 or 2)"
echo "1) Yes"
echo "2) No"
read input
then
echo "setup firewall rules appropriately and startup script"
sudo sed -i 's/#net.ipv4.ip_forward=1/net.ipv4.ip_forward=1/g' /etc/sysctl.conf
rclocalfile="/etc/rc.local"
sudo cp $rclocalfile /etc/rc.local$now
#sudo rm -f $rclocalfile
sudo sed -i 's/#exit 0/#exit 0/g' $rclocalfile
echo "sudo ifdown $wired_nic">>$rclocalfile
echo "sudo ifup $wired_nic">>$rclocalfile
echo "sleep 5">>$rclocalfile
echo "service hostapd restart">>$rclocalfile
echo "service isc-dhcp-server restart">>$rclocalfile
echo "exit 0">>$rclocalfile
sudo iptables -F
sudo iptables -t nat -A POSTROUTING -o $wired_nic -j MASQUERADE
sudo iptables -A FORWARD -i $wired_nic -o $wlan_nic -m state --state RELATED,ESTABLISHED -j ACCEPT
sudo iptables -A FORWARD -i $wlan_nic -o $wired_nic -j ACCEPT
sudo iptables -A OUTPUT -p tcp --tcp-flags ALL ALL -j DROP
sudo iptables -A OUTPUT -p tcp --tcp-flags ALL ACK,RST,SYN,FIN -j DROP
sudo iptables -A OUTPUT -p tcp --tcp-flags SYN,FIN SYN,FIN -j DROP
sudo iptables -A OUTPUT -p tcp --tcp-flags SYN,RST SYN,RST -j DROP
sudo iptables -A OUTPUT -p tcp --tcp-flags ALL NONE -j DROP
sudo rm -f /etc/iptables.ipv4.nat
sudo sh -c "iptables-save > /etc/iptables.ipv4.nat"
#sudo sed -i 's/#net.ipv4.ip_forward=1/net.ipv4.ip_forward=1/g' /etc/sysctl.conf
sudo echo "up iptables-restore < /etc/iptables.ipv4.nat">> /etc/network/interfaces
echo "Done setting up startup script with Firewall Rules"
fi
#Change Password
echo "Would you like to change root password?"
echo "1) Yes"
echo "2) No"
read changepass
if [ $changepass = "1" ];
then
echo "Enter new password"
read S1
echo "Re-Enter new password"
read S2
if [ "$S1" = "$S2" ];
then
echo "pi:S1" | chpasswd
echo "Password changed"
else
echo "Passwords didnt match, password NOT changed"
fi
fi
#Remove unnecessary packages
echo "Remove Unnecessary packages? (Enter 1 or 2)"
echo "1) Yes"
echo "2) No"
read input
then
echo "Removing Unncessary Packages"
# GUI-related packages
pkgs="
alsa-utils
debian-reference-en
desktop-base
dillo
epiphany-browser
gir1.2*
gksu
gnome-icon-theme
gnome-themes-standard-data
gnome*
gstreamer1.0-libav
gstreamer1.0-omx
gstreamer1.0-plugins-bad gstreamer1.0-alsa
gstreamer1.0-plugins-base
gstreamer1.0-plugins-good
gstreamer1.0-x
gtk2-engines
idle
idle3
idle3 python3-tk
java-common
libgtk-3-common
libreoffice*
libx11-.*
lightdm
lxde lxtask
lxde-icon-theme
lxpolkit
menu-xdg
minecraft-pi
minecraft-pi
netsurf-gtk
nuscratch
nuscratch
omxplayer
oracle-java8-jdk
penguinspuzzle
penguinspuzzle
pistore
python-minecraftpi
python-picamera
python-pifacecommon
python-pifacedigitalio
python-pygame
python-serial
python-tk
python3-minecraftpi
python3-numpy
python3-picamera
python3-pifacecommon
python3-pifacedigital-scratch-handler
python3-pifacedigitalio
python3-pygame
python3-rpi.gpio
python-gpiozero
python3-serial
qt50-quick-particle-examples
qt50-snapshot
raspberrypi-artwork
raspberrypi-ui-mods
scratch
smartsim
sonic-pi
timidity
weston
wolfram-engine
x11-common*
x2x
xinit
xkb-data
xpdf
xserver-xorg
xserver-xorg-video-fbdev
xserver-xorg-video-fbturbo
zenity
# Remove packages
for i in $pkgs; do
sudo apt-get -y remove --purge $i
done
# Remove automatically installed dependency packages
sudo apt-get -y autoremove
echo "Updating Pi"
sudo apt-get update
sudo apt-get clean
#echo "Installing Exfat Support"
#echo "Upgrading Packages"
#sudo apt-get upgrade
echo "Done removing unnecessary packages and updates. Rebooting Now!"
#sudo reboot
fi
#Finish up
echo "Config complete, would you like to reboot?"
echo "1) Yes"
echo "2) No"
read reboot
if [ $reboot = "1" ];
then
sudo reboot
else
exit 0
fi
Re: RPI2 Into Wireless Router Config Script
Posted: Tue Mar 15, 2016 12:44 pm
by FreddieG
sorry to ask such basics, I am very new to RPI - but how can I run this script?
I copy/past text into file bash.sh and tried to type sudo bash.sh but to no joy.
Pls advise - thanks
Posted: Mon Mar 28, 2016 1:56 am
by cannonfodder728
you will have to mark the script executable with
sudo chmod a+x bash.sh
then execute with
sudo sh ./bash.sh
