Linkan
IPv4 forwarding from RPi 2 to RPi zero via OTG cable
Wed Feb 17, 2016 1:45 pm
I am trying to use my raspberry pi zero together with my raspberry pi 2 and I want to share network access from my raspberry pi 2 to my raspberry pi zero. I can easily create a local network connection between my raspberry pis, but I have a problem sharing network access.
First of I followed this guide to turn my raspberry pi zero into a ethernet gadget. Then I added this to /etc/network/interfaces:
    allow-hotplug usb0
    iface usb0 inet static
            address 10.0.1.2
            netmask 255.255.255.0
            gateway 10.0.0.1
I configured usb0 on my raspberry pi 2 like this:
    allow-hotplug usb0
            address 10.0.1.1
            gateway 10.0.0.1
I could ssh into my raspberry pi zero with ssh pi@10.0.1.2 but my next goal was to share network access, so I could run stuff like ping google.com on my raspberry pi zero. I found this guide which explains how to forward network access from wlan0 to eth0 and I tried doing the same with usb0.
I added pre-up iptables-restore < /etc/network/iptables.conf to /etc/network/interfaces. This is the content of my iptables.conf file:
    # Generated by iptables-save v1.4.21 on Tue Feb 16 16:41:38 2016
    *mangle
    :PREROUTING ACCEPT [472:58950]
    :INPUT ACCEPT [324:32281]
    :FORWARD ACCEPT [0:0]
    :OUTPUT ACCEPT [30694:35635555]
    :POSTROUTING ACCEPT [30694:35635555]
    COMMIT
    # Completed on Tue Feb 16 16:41:38 2016
    *filter
    :INPUT ACCEPT [57:4180]
    :OUTPUT ACCEPT [2194:2536976]
    -A FORWARD -i usb0 -j ACCEPT
    -A FORWARD -i wlan0 -m state --state RELATED,ESTABLISHED -j ACCEPT
    COMMIT
    *nat
    :PREROUTING ACCEPT [6:821]
    :INPUT ACCEPT [1:242]
    :OUTPUT ACCEPT [0:0]
    :POSTROUTING ACCEPT [0:0]
    -A POSTROUTING -o wlan0 -j SNAT --to-source 10.0.0.115
    COMMIT
I enabled ip forwarding in the kernel by uncommenting this line in etc/sysctl.conf
    # Uncomment the next line to enable packet forwarding for IPv4
    net.ipv4.ip_forward=1
Finally I executed sysctl --system.
Unfortunently network is still unreachable on my raspberry pi zero after rebooting both my raspberry pi 2 and raspberry pi zero. This is the output of route on my raspberry pi 2:
    Kernel IP routing table
    Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
    default         10.0.0.1        0.0.0.0         UG    0      0        0 wlan0
    10.0.0.0        *               255.255.255.0   U     0      0        0 wlan0
    10.0.1.0        *               255.255.255.0   U     0      0        0 usb0
plugwash
Re: IPv4 forwarding from RPi 2 to RPi zero via OTG cable
Thu Feb 18, 2016 11:20 am
Your gateway settings on USB0 are wrong. On the zero the gateway addresss should be the address of the pi2. On the pi2 no gateway should be set on USB0 (one should be set on the interface the pi2 uses to connect to the internet).
Linkan
Thu Feb 18, 2016 12:01 pm
plugwash wrote:Your gateway settings on USB0 are wrong. On the zero the gateway addresss should be the address of the pi2. On the pi2 no gateway should be set on USB0 (one should be set on the interface the pi2 uses to connect to the internet).
So I changed /etc/network/interfaces on the pi zero to:
source-directory /etc/network/interfaces.d
auto lo
iface lo inet loopback
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet manual
    wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
allow-hotplug wlan1
iface wlan1 inet manual
allow-hotplug usb0
        address 10.0.1.2
        gateway 10.0.2.1
And on the pi 2:
auto lo
allow-hotplug wlan0
iface wlan0 inet static
address 10.0.0.115
gateway 10.0.0.1
dns-nameservers 10.0.0.1 8.8.8.8 8.8.4.4
wpa-conf /etc/wpa.conf
allow-hotplug usb0
address 10.0.1.1
This is the output of route on the pi zero:
link-local      *               255.255.0.0     U     203    0        0 usb0
Unfortunately stuff like ping 10.0.0.150 still fails ("connect: Network is unreachable").
plugwash
Thu Feb 18, 2016 12:09 pm
Erm, according to what you just pasted you set the gateway on the pi0 to 10.0.2.1 but the address on the pi2 to 10.0.1.1
Linkan
Thu Feb 18, 2016 12:15 pm
plugwash wrote:Erm, according to what you just pasted you set the gateway on the pi0 to 10.0.2.1 but the address on the pi2 to 10.0.1.1
Ahah, thanks plugwash. How silly of me... :oops:
After correctly setting the gateway to 10.0.1.1 on the pi zero and rebooting everything, I can do ping 10.0.0.150 and ping google.com from my pi zero via merely one cable plugged into my pi zero!
Thanks a lot for the help!
rotwang
Thu Feb 18, 2016 1:19 pm
Glad you found a solution that works for you, my solution was somewhat different, but whatever works for you.
You may find it worthwhile to investigate using the g_cdc module rather then g_ether, it's main advantage being that it appears to the host as a usb-serial port (/dev/ttyACM0) in addition to an ethernet port. This is extremely useful when setting up, as it means you can get a serial login to set up networking (via minicom from your host), as opposed to using ssh, where you need to get everything network related right before you can login at all. The other big advantage is that if you need to reboot the Pi Zero, minicom will hang in there and re-connect, as opposed to ssh dropping the connection.
Linkan
Thu Feb 18, 2016 4:52 pm
rotwang wrote:Glad you found a solution that works for you, my solution was somewhat different, but whatever works for you.
Yeah, I used a USB to TTL cable to get a serial console where I could configure networking. Thanks for the tip by the way!
Linkan
Sun Feb 21, 2016 6:32 pm
So after a couple of days this solution works really good. I have one small problem however. If I reboot my rpi 2, the network connection will not automatically reestablish itself and I have to restart my rpi zero aswell.
Can I somehow make sure the connection between my rpi zero and rpi 2 is reestablished if I restart my rpi 2?
Linkan
Mon Feb 22, 2016 1:03 pm
Does anyone have any suggestions? :?:
Mon Feb 22, 2016 1:10 pm
I assume there's an
iface usb0 inet manual
line in your interfaces file (or something like that). Have you got a matchng
auto usb0
or
allow-hotplug usb0
in your inerfaces file?
Linkan
Mon Feb 22, 2016 3:41 pm
DougieLawson wrote:I assume there's an
auto usb0
or
allow-hotplug usb0
This is my interface file on the pi 2:
auto lo
allow-hotplug wlan0
address 10.0.0.115
gateway 10.0.0.1
allow-hotplug usb0
address 10.0.1.1
This is the interface file on my pi zero:
auto lo
allow-hotplug wlan0
allow-hotplug wlan1
allow-hotplug usb0
        address 10.0.1.2
        gateway 10.0.1.1
	dns-nameservers 10.0.1.1 8.8.8.8 8.8.4.4
Again, this works fine. Only I have an issue where rebooting the pi 2 causes the network access on the pi zero to drop and I have to reboot it aswell. Maybe this can be "solved" by rebooting the pi zero whenever the pi 2 reboots?
Mon Feb 22, 2016 11:49 pm
Is it running Rasbian Wheezy or Raspbian Jessie?
Linkan
Mon Feb 22, 2016 11:58 pm
DougieLawson wrote:Is it running Rasbian Wheezy or Raspbian Jessie?
Latest version of Raspbian Jessie downloaded from raspberrypi.org.
Tue Feb 23, 2016 12:59 am
Then you need to undo all the changes you've made to /etc/network/interfaces and simply add two lines for your USB network device (if it doesn't appear as eth0 or wlan0).
All network configuration stuff is done in /etc/dhcpcd.conf on Jessie.
