flightisfun2001
RPI Web Server
Mon Feb 15, 2016 1:04 am
I'm having trouble with my Raspberry Pi as a web server. I followed the instructions given in the Raspberry PI user guide:
Sudo apt-get update
Sudo apt-get install apache2 php5 php5-mysql mysql-server
[Enter and confirm MySQL password]
Sudo sh -c 'echo "<?php phpinfo(); ?>" >/var/www/phptest.php'
So then I tried this both on my Raspbian Jessie Raspberry PI 2 on the Netsurf Web Browser and Safari on a Mac OS X Yosemite computer:
On Mac: http://ipaddress/phptest.php (ipaddress filled with actual ip address)
Results: Random Xfinity page showing all the computers on the network.
On Raspbian: http://localhost/phptest.php
Results: Page not found.
Can any web server expert help with this?
Thanks a lot,
Nathan Jones
flightisfun2001
Re: RPI Web Server
Mon Feb 15, 2016 1:15 am
See previous message.
Also, I Googled my IP address on a Mac on the same network and got the same answer. Perhaps it was the router's IP address? But still, if the localhost one didn't work, that means that something isn't right, correct? :?
Re: RPI Web Server
Mon Feb 15, 2016 2:52 am
I presume you meant "sudo" not "Sudo".
Are you using Jessie on your Pi?
I think the apache server root has changed recently. On the jessie on my PC it's /var/www/html
So the command:
sudo sh -c 'echo "<?php phpinfo(); ?>" >/var/www/html/phptest.php'
Gets that info page working nicely here on http://localhost/phptest.php
flightisfun2001
Re: RPI Web Server
Tue Feb 16, 2016 11:01 pm
Yes, I did mean "sudo" rather than "Sudo". I am using Jessie.
Thanks!
Re: RPI Web Server
Tue Feb 16, 2016 11:02 pm
So, did my suggestion work or not ?
Others might like to know.
asandford
Re: RPI Web Server
Tue Feb 16, 2016 11:21 pm
What are the permissions of the folder /var/www/? What user is Apache running as? Has Apache got permission to execute (via php) /var/www/phptest.php?
Running every command as root with sudo may overcome some problems, but can create many more (much like someone I used to work with who would chmod everything as 777 as permissions 'got in the way' :roll: ).
flightisfun2001
Re: RPI Web Server
Thu Mar 03, 2016 2:41 am
The terminal command made it so that when I went to http://localhost/phptest.php I got this message: 403 - Forbidden. :!:
Dutch_Master
Re: RPI Web Server
Thu Mar 03, 2016 3:18 am
I've answered your question here: viewtopic.php?f=63&t=138410 Why did you start a new thread?
texy
Re: RPI Web Server
Thu Mar 03, 2016 8:02 am
Locking as new thread created here :
Texy
