morphy_richards
HTML 5 clientless browser based remote desktop for pi
Thu Feb 11, 2016 3:21 pm
I am going to have a go at doing this but wanted to pop the idea up here as well.
I have had some success using this system http://guac-dev.org/ on cloud based virtual installations of Ubuntu. If you havent come across it before, it allows a VNC like connection to a remote computer but the 'client' needs have no special software other than a html5 compliant web browser.
I would like to try installing this guac system on a pi zero with ethernet gadget mode. That would allow you to put http://169.254.64.64 into a web browser on the 'client' computer and be presented with a remote desktop to the pi zero inside the web browser.
I think this would have merit because nothing special needs to be done to to other computers such as installing VNC, in theory just plug and play. Especially useful in locked down educational establishments.
This normally works by using apache tomcat. I'm not sure how well this would work out with a raspberry pi, (it's the method I will try first however , just because ... I know how to do it)
I wonder if there might be a better-for-a-pi java servlet system out there though, perhaps nginx / jetty?
Last edited by morphy_richards on Wed Feb 17, 2016 8:08 am, edited 1 time in total.
morphy_richards
Re: HTML 5 clientless browser based remote desktop for pi ze
Fri Feb 12, 2016 5:05 pm
Hmm .. fallen at the first hurdle
pi@raspberrypi:~ $ sudo apt-get update
Err http://archive.raspberrypi.org jessie InRelease
Err http://mirrordirector.raspbian.org jessie InRelease
Err http://archive.raspberrypi.org jessie Release.gpg
  Could not resolve 'archive.raspberrypi.org'
Err http://mirrordirector.raspbian.org jessie Release.gpg
  Could not resolve 'mirrordirector.raspbian.org'
Reading package lists... Done
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/jessie/InRelease
W: Failed to fetch http://archive.raspberrypi.org/debian/dists/jessie/InRelease
W: Failed to fetch http://archive.raspberrypi.org/debian/dists/jessie/Release.gpg  Could not resolve 'archive.raspberrypi.org'
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/jessie/Release.gpg  Could not resolve 'mirrordirector.raspbian.org'
W: Some index files failed to download. They have been ignored, or old ones used instead.
pi@raspberrypi:~ $ ping 8.8.8.8
connect: Network is unreachable
How do I pass the internet connection from my host computer to my pi zero? (I'm using mikerr's image)
mattmiller
Fri Feb 12, 2016 5:09 pm
Great initiative if you can get it working :)
rotwang
Fri Feb 12, 2016 5:21 pm
morphy_richards wrote:Hmm .. fallen at the first hurdle
Can you ping the pi from the host and vice versa? If you can do that, then you need to ip-forward the connection from the pi to the host's internet connection. I have this working on a stock jessie install, rpi-updated to the experimental 4.4.1 kernel and it's working fine. Writing it up is not going quite so well, not helped by having two terminal windows on the host, one of which was logged onto the pi, and then doing poweroff in the wrong window.
Rest assured it's perfectly possible, the documentation just takes a little longer (Now where have I heard that before, I wonder)
Roger
morphy_richards
Fri Feb 12, 2016 5:46 pm
No .. funnily enough
I've plugged my pizero into the raspberry pi that controls my aquarium out of convenience....
pi@aquariumpi ~ $ ping 169.254.64.64
PING 169.254.64.64 (169.254.64.64) 56(84) bytes of data.
64 bytes from 169.254.64.64: icmp_req=1 ttl=64 time=0.615 ms
64 bytes from 169.254.64.64: icmp_req=2 ttl=64 time=0.493 ms
^C
--- 169.254.64.64 ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 1001ms
rtt min/avg/max/mdev = 0.493/0.554/0.615/0.061 ms
That much works
pi@aquariumpi ~ $ ssh pi@169.254.64.64
pi@169.254.64.64's password:
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Wed Dec 30 00:20:28 2015 from aquariumpi.local
pi@raspberrypi:~ $ ping 192.168.0.14
pi@raspberrypi:~ $
But I cannot go back in the other direction :?
skspurling
Sun Feb 14, 2016 2:07 am
morphy_richards wrote:No ..
So, do a ifconfig and verify the ip address you are connecting from? Sounds simplistic, but I know I've been bitten more times by assuming I knew something and not double checking it. Clearly you have 2 way communications, otherwise SSH would not work.
morphy_richards
Mon Feb 15, 2016 11:07 am
Success, (kind of)
To quickly summarise - I want to be able to display the desktop of a pi zero in ethernet gadget mode in the web browser of the host computer. No need to install VNC. It can be done!
However, I cant get my pi zero to work properly. This has actually been done on a pi B +, but I think it shows that you can further increase the versatility of a pi zero because now you can access the desktop without special cables and there is no need to install anything special like VNC on the host computer. Just an ordinary, modern web browser is needed.
Here is a quick writeup of what I did.
(following the set of steps described in chapter 2 and chapter 5 of the Guacamole manual.)
Install the first set of dependencies
sudo apt-get install libcairo2-dev libjpeg62-turbo-dev libpng12-dev libossp-uuid-dev
Install the second set of dependencies
sudo apt-get install libfreerdp-dev libpango1.0-dev libssh2-1-dev libvncserver-dev libpulse-dev libssl-dev libvorbis-dev libwebp-dev
Download the Guacamole source code, uncompress it and then change into the new directory.
wget http://downloads.sourceforge.net/project/guacamole/current/source/guacamole-server-0.9.9.tar.gz
tar -zxvf guacamole-server-0.9.9.tar.gz
cd guacamole-server-0.9.9
Now we will compile Guacamole and set it up so that it starts when the pi starts.
sudo ./configure -with-init-dir=/etc/init.d
sudo make
sudo make install
When finished, change out of the guacamole directory, back to home directory, download and uncompress the guacamole client source code.
cd
wget http://sourceforge.net/projects/guacamole/files/current/source/guacamole-client-0.9.9.tar.gz
tar -zxvf guacamole-client-0.9.9.tar.gz
cd guacamole-client-0.9.9
Install some extra tools needed to compile the client
 sudo apt-get install maven
Install Apache Tomcat . This makes your pi zero into a powerful dynamic java servlet web server and allows it to broadcast desktops visually with HTML5 over the network into client web browsers.
sudo apt-get install tomcat7 tomcat7-admin tomcat7-docs
Compile the Guacamole client.
mvn package
Now we will copy the compiled .war file to the Tomcat directory.
sudo cp guacamole/target/guacamole-0.9.9.war /var/lib/tomcat7/webapps/guacamole.war
Create a location for Guacamole configuration files.
 sudo mkdir /etc/guacamole
edit /etc/guacamole/guacamole.properties
# Hostname and port of guacamole proxy
guacd-hostname: localhost
guacd-port: 4822
Now create a connection config file.
edit /etc/guacamole/user-mapping.xml
 <user-mapping>
<!-- Per-user authentication and config information -->
<authorize username="username" password="password">
<protocol>rdp</protocol>
<param name="hostname">localhost</param>
<param name="port">3389</param>
</authorize>
</user-mapping>
Create a directory in tomcat7 for the connection file to go into.
 sudo mkdir /usr/share/tomcat7/.guacamole
Link this to the files you just created.
sudo ln -s /etc/guacamole/guacamole.properties /usr/share/tomcat7/.guacamole
sudo ln -s /etc/guacamole/user-mapping.xml /usr/share/tomcat7/.guacamole
Install RDP client to allow remote desktop broadcasting.
sudo apt-get install rdesktop  freerdp-x11 xrdp
Restart guacamole and tomcat
sudo service guacd restart
sudo service tomcat7 restart
Connect to your pi's remote desktop
http://your_zero_ip_address:8080/guacamole
Last edited by morphy_richards on Wed Feb 17, 2016 7:48 am, edited 3 times in total.
morphy_richards
Mon Feb 15, 2016 11:14 am
Great!
I'll give this a try this evening
AndyPi
Mon Feb 15, 2016 11:59 am
Hi
I did the adafruit tutorial on gadget mode. When it comes to internet sharing they do it on a macOS. To manage it on Ubuntu as host I did the following (BTW I don't really understand what I'm doing but it seems to work.
Need to use ip forwarding which is controlled via a sysctl value. To view
sysctl net.ipv4.ip_forward
As with any sysctl kernel parameters we can change the value of net.ipv4.ip_forward on the fly (without rebooting the system):
sysctl -w net.ipv4.ip_forward=1
If we want to make this configuration permanent the best way to do it is using the file /etc/sysctl.conf where we can add a line containing
net.ipv4.ip_forward = 1
if you already have an entry net.ipv4.ip_forward with the value 0 you can change that 1.
To enable the changes made in sysctl.conf you will need to run the command:
sysctl -p /etc/sysctl.conf
Fot the next bit need to be root so...
sudo su
iptables --table nat --append POSTROUTING --out-interface eth0 -j MASQUERADE
iptables --append FORWARD --in-interface usb0 -j ACCEPT
Do not forget to save these IPTables rules. Unless they are saved, they will be lost after next system reboot as they are stored in volatile memory.
iptables-save > /etc/iptables.rules
Above command will activate previously saved IPTables rules when system reboots making the changes permanent.
In the adafruit example the zero is set with address 192.168.7.2, I think I had to add
dns-nameservers 8.8.8.8 8.8.4.4
to the interfaces file
This may be of some help
regards
gunkan
Mon Feb 15, 2016 12:46 pm
Amazing :shock: I am quite busy with work now, but i will give it a try as soon as possible.
morphy_richards
Mon Feb 15, 2016 2:39 pm
You will see two login screens.
The first lets guacamole pass through to your desktop login. There is a way to disable it using a 'noauth' module which I will configure and writeup later.
Then there is the standard login, this can be disabled by supplying credentials for RDP in usermapping.xml
mattmiller
Mon Feb 15, 2016 10:53 pm
All seems to have gone well
suggestion change the edit ... files
to
sudo nano ........
so they get created as they are the only lines that can#t be simply copy and pasted :)
Now I'm at the login screen
Tried
pi
raspberry
tried my windows login and password
neither seems to work :(
This is on 2B BTW
morphy_richards
Tue Feb 16, 2016 6:25 am
What is in your /etc/guacamole/user-mapping.xml?
Also, /var/log/tomcat7/catalina.out?
morphy_richards
Tue Feb 16, 2016 6:44 am
Forgot to mention, you may need to manually start guac daemon.
Sudo service guacd start
Then sudo service tomcat7 restart
mattmiller
Tue Feb 16, 2016 7:27 am
re /etc/guacamole/user-mapping.xml
I didn't notice that I needed username/password as my username/password
Do you have yours set to standard pi/raspberry ?
Anyway - got thru 1st login but then get
An internal error has occurred within the Guacamole server, and the connection has been terminated. If the problem persists, please notify your system administrator, or check your system logs.
mattmiller
Tue Feb 16, 2016 7:34 am
INFO: Deployment of web application archive /var/lib/tomcat7/webapps/guacamole.war has finished in 33,786 ms
Feb 16, 2016 7:30:45 AM org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deploying web application directory /var/lib/tomcat7/webapps/ROOT
Feb 16, 2016 7:30:49 AM org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deployment of web application directory /var/lib/tomcat7/webapps/ROOT has finished in 4,049 ms
Feb 16, 2016 7:30:49 AM org.apache.coyote.AbstractProtocol start
INFO: Starting ProtocolHandler ["http-bio-8080"]
Feb 16, 2016 7:30:49 AM org.apache.catalina.startup.Catalina start
INFO: Server startup in 41888 ms
07:31:36.545 [http-bio-8080-exec-1] INFO  o.g.g.n.b.r.a.AuthenticationService - User "username" successfully authenticated from 192.168.0.16.
07:31:39.671 [http-bio-8080-exec-9] ERROR o.g.g.n.b.w.t.GuacamoleWebSocketTunnelServlet - Creation of WebSocket tunnel to guacd failed: java.net.ConnectException: Connection refused
07:31:57.944 [http-bio-8080-exec-1] ERROR o.g.g.n.b.w.t.GuacamoleWebSocketTunnelServlet - Creation of WebSocket tunnel to guacd failed: java.net.ConnectException: Connection refused
07:32:15.932 [http-bio-8080-exec-5] ERROR o.g.g.n.b.w.t.GuacamoleWebSocketTunnelServlet - Creation of WebSocket tunnel to guacd failed: java.net.ConnectException: Connection refused
07:32:33.965 [http-bio-8080-exec-7] ERROR o.g.g.n.b.w.t.GuacamoleWebSocketTunnelServlet - Creation of WebSocket tunnel to guacd failed: java.net.ConnectException: Connection refused
<user-mapping>
</authorize>
</user-mapping>
morphy_richards
Tue Feb 16, 2016 7:41 am
That's a new one . ..
Have a look in /var/log/syslog
I have a vague suspicion guacd isnt started as well.
See if it shows up with
sudo service --status-all
mattmiller
Tue Feb 16, 2016 9:26 am
Feb 16 09:24:08 raspberrypi systemd[1]: Stopping LSB: Guacamole proxy daemon...
Feb 16 09:24:08 raspberrypi guacd[3071]: Stopping guacd: SUCCESS
Feb 16 09:24:08 raspberrypi systemd[1]: Starting LSB: Guacamole proxy daemon...
Feb 16 09:24:08 raspberrypi guacd[3078]: Guacamole proxy daemon (guacd) version 0.9.9 started
Feb 16 09:24:08 raspberrypi guacd[3076]: Starting guacd: guacd[3078]: INFO:#011Guacamole proxy daemon (guacd) version 0.9.9 started
Feb 16 09:24:08 raspberrypi guacd[3076]: SUCCESS
Feb 16 09:24:08 raspberrypi guacd[3080]: Listening on host 127.0.0.1, port 4822
Feb 16 09:24:08 raspberrypi systemd[1]: Started LSB: Guacamole proxy daemon.
Feb 16 09:24:16 raspberrypi systemd[1]: Stopping LSB: Start Tomcat....
Feb 16 09:24:17 raspberrypi tomcat7[3098]: Stopping Tomcat servlet engine: tomcat7.
Feb 16 09:24:17 raspberrypi systemd[1]: Starting LSB: Start Tomcat....
Feb 16 09:24:22 raspberrypi tomcat7[3113]: Starting Tomcat servlet engine: tomcat7.
Feb 16 09:24:22 raspberrypi systemd[1]: Started LSB: Start Tomcat..
[ - ]  checkroot-bootclean.sh
 [ - ]  checkroot.sh
 [ + ]  console-setup
 [ + ]  cron
 [ + ]  dbus
 [ + ]  dhcpcd
 [ + ]  dphys-swapfile
 [ + ]  fake-hwclock
 [ + ]  guacd
 [ + ]  hdparm
 [ - ]  hostname.sh
 [ - ]  hwclock.sh
 [ + ]  kbd
morphy_richards
Tue Feb 16, 2016 3:42 pm
Did you make symbolic links from
and
to /usr/share/tomcat7/.guacamole ?
Does anything different show up in catalina.out after you do a sudo service tomcat7 restart?
Here's my user-mapping.xml again, directly out of emacs on my pi
 <user-mapping>
 <authorize username="pi" password="raspberry">
 </authorize>
 </user-mapping>
and guacamole.properties
guacd-port: 4822
morphy_richards
Tue Feb 16, 2016 3:48 pm
 [ - ]  checkroot.sh
 [ + ]  console-setup
 [ + ]  cron
 [ + ]  dbus
 [ + ]  dhcpcd
 [ + ]  fake-hwclock
 [ + ]  guacd
 [ + ]  hdparm
 [ - ]  hostname.sh
 [ - ]  hwclock.sh
 [ + ]  kbd
You also seem short of a few services, eg. rdp. (Remote Desktop) and tomcat. Did you do sudo apt-get install rdesktop freerdp-x11 xrdp ?
I am running
pi@raspberrypi:~ $ sudo service --status-all
 [ - ]  alsa-utils
 [ + ]  avahi-daemon
 [ - ]  bootlogs
 [ - ]  bootmisc.sh
 [ - ]  checkfs.sh
 [ - ]  checkroot.sh
 [ + ]  console-setup
 [ + ]  cron
 [ + ]  dbus
 [ + ]  dhcpcd
 [ + ]  fake-hwclock
 [ + ]  guacd
 [ + ]  hdparm
 [ - ]  hostname.sh
 [ - ]  hwclock.sh
 [ + ]  kbd
 [ + ]  keyboard-setup
 [ - ]  killprocs
 [ + ]  kmod
 [ + ]  lightdm
 [ - ]  motd
 [ - ]  mountall-bootclean.sh
 [ - ]  mountall.sh
 [ - ]  mountdevsubfs.sh
 [ - ]  mountkernfs.sh
 [ - ]  mountnfs-bootclean.sh
 [ - ]  mountnfs.sh
 [ + ]  networking
 [ - ]  nfs-common
 [ + ]  ntp
 [ - ]  plymouth
 [ - ]  plymouth-log
 [ + ]  procps
 [ + ]  raspi-config
 [ + ]  rc.local
 [ - ]  rmnologin
 [ - ]  rpcbind
 [ - ]  rsync
 [ + ]  rsyslog
 [ - ]  sendsigs
 [ + ]  ssh
 [ - ]  sudo
 [ + ]  tomcat7
 [ + ]  triggerhappy
 [ + ]  udev
 [ + ]  udev-finish
 [ - ]  umountfs
 [ - ]  umountnfs.sh
 [ - ]  umountroot
 [ + ]  urandom
 [ - ]  x11-common
 [ + ]  xrdp
mattmiller
Tue Feb 16, 2016 5:13 pm
I was jsut showing you that I was running quacd :)
here is full list
[ - ]  alsa-utils
 [ + ]  avahi-daemon
 [ - ]  bootlogs
 [ - ]  bootmisc.sh
 [ - ]  checkfs.sh
 [ - ]  checkroot.sh
 [ + ]  console-setup
 [ + ]  cron
 [ + ]  dbus
 [ + ]  dhcpcd
 [ + ]  fake-hwclock
 [ + ]  guacd
 [ + ]  hdparm
 [ - ]  hostname.sh
 [ - ]  hwclock.sh
 [ + ]  kbd
 [ - ]  killprocs
 [ + ]  kmod
 [ + ]  lightdm
 [ - ]  motd
 [ + ]  motion
 [ - ]  mountall.sh
 [ - ]  mountnfs.sh
 [ + ]  networking
 [ - ]  nfs-common
 [ + ]  ntp
 [ - ]  plymouth
 [ - ]  plymouth-log
 [ + ]  procps
 [ + ]  raspi-config
 [ + ]  rc.local
 [ - ]  rmnologin
 [ - ]  rpcbind
 [ - ]  rsync
 [ + ]  rsyslog
 [ - ]  sendsigs
 [ + ]  ssh
 [ - ]  sudo
 [ + ]  tomcat7
 [ + ]  triggerhappy
 [ + ]  udev
 [ + ]  udev-finish
 [ - ]  umountfs
 [ - ]  umountnfs.sh
 [ - ]  umountroot
 [ + ]  urandom
 [ - ]  x11-common
 [ + ]  xrdp
mattmiller
Tue Feb 16, 2016 6:46 pm
Found the mistook :)
guacd-port: 4822
I'd missed off the last 2 in 4822 when copy/pasting :)
Now in and working :)
Excellent work :)
I decided to use the Asteroid Blaster prog in Scratch to test speed compared to X11VNC that I normally use and the rocks move visibly faster!
However, when I press space to fire - there is a big pause
Need t ocheck more
Matthew
morphy_richards
Wed Feb 17, 2016 6:50 am
In my walkthrough I install OpenJDK. This can / should be omitted as raspbian (as of 2013) comes with oracle Java and its better optimised for pi.
texy
Wed Feb 17, 2016 7:21 am
morphy_richards wrote:In my walkthrough I install OpenJDK. This can / should be omitted as raspbian (as of 2013) comes with oracle Java and its better optimised for pi.
You could edit your walkthrough to remove it maybe?
Is this really for the zero only? If the walkthrough works for any pi model then perhaps we should rewrite/retitle posts.....
Texy
morphy_richards
Wed Feb 17, 2016 7:29 am
I will ...make a more definitive version.
Currently still fiddling, trying to get "noauth'" working to allow direct access to desktop without additional login steps.
