TheGuyUk
Noobs 1.7.0
Wed Feb 10, 2016 6:14 pm
So what has changed in Noobs 1.7.0 ?
Anything worth downloading it for ?
Or am I better of just updating my present Noobs?
Re: Noobs 1.7.0
Wed Feb 10, 2016 6:26 pm
TheGuyUk wrote:So what has changed in Noobs 1.7.0 ?
NOBS was updated to offer the latest Raspbian Jessie Release
NOBS is an operating system installer / chooser / recovery and at present the developers have not offered an upgrade path to newer versions.
Obviously an Operating System installed via NOBS can be updated following the instructions of the developer..
My other Linux machines are a ChromeBox & Intel CoreDuo Desktop
ShiftPlusOne
Re: Noobs 1.7.0
Wed Feb 10, 2016 6:27 pm
Support for Windows 10 IoT has been added.
Re: Noobs 1.7.0
Wed Feb 10, 2016 6:30 pm
ShiftPlusOne wrote:Support for Windows 10 IoT has been added.
That was first offered in 1.6.0 if connected to Internet..
ShiftPlusOne
Re: Noobs 1.7.0
Wed Feb 10, 2016 7:41 pm
If the question is what the difference is between 1.6 and 1.7, then not much. 1.6 had a kernel driver which didn't work with some sd cards. If it works for you, there is no reason to upgrade.
TheGuyUk
Re: Noobs 1.7.0
Thu Feb 11, 2016 4:50 pm
ShiftPlusOne wrote:If the question is what the difference is between 1.6 and 1.7, then not much. 1.6 had a kernel driver which didn't work with some sd cards. If it works for you, there is no reason to upgrade.
thank you
beta-tester
Re: Noobs 1.7.0
Fri Feb 12, 2016 9:21 am
is that the reason, why i don't see any commits since november 2015 on raspberrypi/noobs/commits/master or raspberrypi/noobs/releases, because the source code itself didn't change, only a subsequent dependency changed ?
(the kernel, Raspbian and the os_list.json is not directly part of NOOBS - its their subsequent dependences)
{ I only give negative feedback }
RPi B (256MB), B (512MB), B+, ZeroW; 2B; 3B, 3B+; 4B (4GB)
Re: Noobs 1.7.0
Fri Feb 12, 2016 11:08 am
Many posters have the impression NOBS is an OS, hence confusion...
ShiftPlusOne
Re: Noobs 1.7.0
Fri Feb 12, 2016 1:00 pm
NOOBS has changed since those commits. I am not sure when the latest changes will be in github.
beta-tester
Re: Noobs 1.7.0
Fri Feb 12, 2016 1:11 pm
i thought, everything that is published on RaspberryPi Downloads is in the masters of the rasberrypi github :shock: :o :?
