ashish john
LCD driver
Sun Feb 07, 2016 7:08 am
hello guys ... i recently bought a 3.5inch RPi LCD V3.0 tft for raspberry pi 2 a... i dont know how to configure it. i need ur help... i've tried many raspbian images bt it doesnt work....somebody please help me :
i've purchased it from ebay
http://www.ebay.com/itm/3-5-TFT-LCD-Tou ... Sw5VFWH3Yf
Higgs
Re: LCD driver
Sun Feb 07, 2016 11:48 pm
You can try this
http://www.waveshare.com/wiki/Main_Page#Raspberry_Pi
Listed under "Expansions"
klricks
Re: LCD driver
Mon Feb 08, 2016 1:34 am
Looks like a clone of an Adafruit screen? https://www.adafruit.com/products/2441
Contact the seller. If the seller can't give detailed instructions and driver / image downloads then open an incident report and return it.
wilika
Re: LCD driver
Thu Mar 03, 2016 7:40 pm
That's the exact same screen (and same seller) I've received today.
Also struggling to get it to work. :(
wilika
Re: LCD driver
Thu Mar 03, 2016 8:17 pm
Not sure, how I've managed to make it work, but suddenly, it's running now. :)
start with running
sudo rpi-update
then reboot
(that's the moment, my screen started working)
if it's still blank, then maybe these are needed as well (I've started trying by these instructions);
https://github.com/swkim01/waveshare-dtoverlays
wilika
Re: LCD driver
Thu Mar 03, 2016 11:30 pm
Something took a terrible turn.
I might have bumped out the SDcard while it was working, and it wouldn't start again. So I've reburned the card with a fresh Raspbian, and I'm struggling again. :(
So no, simply running an update, ora even doing the other steps on that link, aren't enough. :((
GTR2Fan
Re: LCD driver
Thu Mar 03, 2016 11:40 pm
Please don't encourage others to try using rpi-update unless it's known to offer a specific fix for a specific problem. Its use is discouraged as it's not part of a standard update and all it brings to an otherwise fully updated install is experimental patches that may break other things.
Pi2B Mini-PC/Media Centre: ARM=1GHz (+3), Core=500MHz, v3d=500MHz, h264=333MHz, RAM=DDR2-1200 (+6/+4/+4+schmoo). Sandisk Ultra HC-I 32GB microSD card on '50=100' OCed slot (42MB/s read) running Raspbian/KODI16, Seagate 3.5" 1.5TB HDD mass storage.
wilika
Re: LCD driver
Thu Mar 03, 2016 11:45 pm
GTR2Fan wrote:Please don't encourage others to try using rpi-update unless it's known to offer a specific fix for a specific problem. Its use is discouraged as it's not part of a standard update and all it brings to an otherwise fully updated install is experimental patches that may break other things.
Good to know, thanks. I'm completely new in this, and had no idea, just the fact, that once I've managed to make it work after using this command.
You might be right, I'v just broken my Raspbian install for the third time this evening. :D
I'll give it another shot tomorrow, without the rpi-upgrade.
Thanks again!
GTR2Fan
Re: LCD driver
Thu Mar 03, 2016 11:53 pm
sudo apt-get update && sudo apt-get upgrade
... is all you should ever normally need.
