rpifreeze
LAN chipset disabled but gets very hot
Fri Aug 03, 2012 2:00 pm
I don't use LAN interface and intentionally disabled smsc95xx module in kernel.
However, when I touch it, it's temperature is the same as BCM chipset.
Is that normal situation ?
Does it mean that I didn't fully disable LAN ?
btw,
I conect to my RPi remotely and use only wifi stick (Asus USB-N10), that works excellent.
usb and broadcom issues will never be solved...Too much time passed, too much to be done...
jdbennet
Re: LAN chipset disabled but gets very hot
Fri Aug 03, 2012 2:08 pm
Its normal for it to get hot. Disabling software support for it doesnt stop it getting power, obviously.
payturr
Fri Aug 03, 2012 9:58 pm
The LAN chip is also the USB chip so, even if you turn off the LAN part you still have the USB part, which I'm pretty sure you need :P
rpifreeze
Sat Aug 04, 2012 4:09 pm
Thank you both for reply.
I will now enable LAN to see if the issue with "RPi freeze" is still valid with newest kernel.
Previously (2 weeks ago, source from git) I had contant kernel panics, but I've just updated my kernel and modules with newest sources and see the results.
Don't you all think that RPi has poor SW support...?
Personally, I think more effort (workhours) should be spent for development and code improvement, because soon we'll realize that we have an excellent engine for which a specific gas is no more sold.
