PicoPi
Raspbian OR Jessie for OpenCV?
Sun Jan 17, 2016 10:25 pm
Hi guys,
Was wondering if there was a difference between how the Camera works in the 2 versions? Can OpenCV still run on Jessie?
SonOfAMotherlessGoat
Re: Raspbian OR Jessie for OpenCV?
Sun Jan 17, 2016 11:19 pm
The latest Raspbian IS Jessie. Do you mean Jessie OR Wheezy?
Account Inactive
PicoPi
Mon Jan 18, 2016 12:42 am
I'm running the old Raspbian and want to upgrade to Jessie, but won't if it doesn't work with OpenCV.
W. H. Heydt
Mon Jan 18, 2016 1:01 am
PicoPi wrote:I'm running the old Raspbian and want to upgrade to Jessie, but won't if it doesn't work with OpenCV.
Get another SD card. Load Jessie on it. Do everything in OpenCV on the new card that you're doing on the current card. Then you'll know if it works for what you're doing.
(It probably will. Very few programs change behavior with an OS release change.)
jmmec
Mon Jan 18, 2016 1:45 pm
FWIW, I am running Jessie Lite. I compiled OpenCV 3 on my Pi2 (from instruction found on the web) and it works just fine interfacing with the camera. I use OpenCV with the Python Picamera library.
PicoPi
Mon Jan 18, 2016 2:01 pm
jmmec wrote:FWIW, I am running Jessie Lite. I compiled OpenCV 3 on my Pi2 (from instruction found on the web) and it works just fine interfacing with the camera. I use OpenCV with the Python Picamera library.
Excellent. Thanks
