buffmasterbran
GPIO to SPI
Mon Jan 11, 2016 7:44 pm
Is it possible to modify the Raspberry Pi so there are 2 SPI MOSI/MISO and in doing so, using up 2 of the GPIO's?
FTrevorGowen
Re: GPIO to SPI
Mon Jan 11, 2016 8:16 pm
buffmasterbran wrote:Is it possible to modify the Raspberry Pi so there are 2 SPI MOSI/MISO and in doing so, using up 2 of the GPIO's?
Not quite sure what you want to do. The Pi currently supports two SPI interfaces using common MOSI/MISO/SCLK GPIO's + two ¬CE GPIO's. More ¬CE signals can be added by gating the existing ones with other GPIO's. Alternatively it's also possible to "bit-bang" additional SPI interfaces** (but that requires more GPIO's).
Trev.
** As I did in this test/demo circuit here:
http://www.cpmspectrepi.webspace.virgin ... Lvspi.html
Still running Raspbian Jessie on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W) but Stretch on my 2xP3A+, P3B+, P3B, B+, A+ and a B2. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
RogerW
Re: GPIO to SPI
Tue Jan 12, 2016 9:30 am
PIs with 40 pin headers (A+, B+, B2) have two SPI interfaces anyway. The primary one uses GPIOs 9,10,11 and one of two chip selects 7,8. The extra port uses 19,20,21 with three chip selects 11,12,36.
Burngate
Re: GPIO to SPI
Tue Jan 12, 2016 9:41 am
RogerW wrote:... with three chip selects 11,12,36.
Actually GPIOs 16, 17, 18 on header pins 36, 11, 12 respectively
karrika
Re: GPIO to SPI
Tue Jan 12, 2016 9:53 am
SPI pins in a nice graphical view http://pinout.xyz/pinout/spi
RogerW
Re: GPIO to SPI
Tue Jan 12, 2016 9:55 am
Burngate wrote:Actually GPIOs 16, 17, 18 on header pins 36, 11, 12 respectively
Thanks for correcting that - I misread the comments in my code.
FTrevorGowen
Re: GPIO to SPI
Tue Jan 12, 2016 2:31 pm
RogerW et al wrote: PIs with 40 pin headers (A+, B+, B2) have two SPI interfaces anyway.
Thanks folks for adding that info. (I had a vague recollection that there was a second set, but didn't have the time to check further when I replied to the O.P.)
Trev.
buffmasterbran
Re: GPIO to SPI
Tue Jan 12, 2016 2:52 pm
I found an answer. I need a small display to run on GPIO's and not on the SPI's. I am very new to all of this so someone told me to figure out how to big-bang GPIO's to SPI.
https://www.youtube.com/watch?v=4U9TWmFlZDo
Thank you all for you responses.
