tee1
sql queries in php
Sat Jan 09, 2016 6:17 pm
Hie everyone.
l am working on a project that involves connecting a php application and MySQL database. Connection to the database is made successfully but the problem is that all queries to the database using php are failing. l did install the php5-mysql package. The code below shows a query to add a record to the table 'users':
<?php
$dbUser="root";
$dbPass="<mypassword>";
$dbDatabase="<databasename>";
$dbHost="localhost";
$dbConn=mysql_connect($dbHost,$dbUser,$dbPass);
if(dbConn){
mysql_select_db($dbDatabase);
print("Successful connection");
mysql_query(INSERT INTO 'users' ('username','password') VALUES('<myusername>','<mypassword>'));
}else{
print("Connection failed");
When l go to the 'users' table nothing will have been added but on the webpage it print Successful connection. Your help will be really appreciated
Re: sql queries in php
Sun Jan 10, 2016 12:52 am
Test the results from both your connection and your database select.
<?php
 $dbconn = mysql_connect('localhost', 'someuseridhere', 'somesupersecretpasswordhere' );
 if (!$dbconn) {
        die('DB001T DB Connection Error: ' . mysql_error());
 $dbsel = mysql_select_db('LOG_DB', $dbconn);
 if (!$dbsel) {
        die('DB002T Can\'t use database LOG_DB: ' . mysql_error());
And again when you run your SQL
$rrows = mysql_query($isrtrow) or die("DB003E ".mysql_error());
aelsas
Sun Jan 10, 2016 2:27 pm
Is it really 'users'? Normally table names without ' ' in SQL!
Sun Jan 10, 2016 8:58 pm
aelsas wrote:Is it really 'users'? Normally table names without ' ' in SQL!
Actually, normally with backticks to identify a table, row or column identifier. The single quotes would indicated a literal value. Oh, and the whole query should be in double quotes too.
mysql_query("INSERT INTO `users` (`username`,`password`) VALUES('<myusername>','<mypassword>')");
Jim Manley
Location: SillyCon Valley, California, and Powell, Wyoming, USA, plus The Universe
Mon Jan 11, 2016 3:56 am
Backticks are optional because they're meant to allow creation of column names and other identifiers that contain spaces and reserved words and characters, although reserved elements should absolutely be avoided for obvious reasons.
