RPI crashes often after reboot
Posted: Fri Jan 08, 2016 8:52 am
by mba75
Hi there
Any of you run into the same issue as me?
The RPi2 often crashes or dosen´t boot up properly, after I reboot it when haveng done some configuration on it.
If any of you have experienced something similar, do you know a fix on it?
Re: RPI crashes often after reboot
Posted: Fri Jan 08, 2016 9:36 am
by davidcoton
What operating system are you using?
What power supply are you using?
What peripherals are connected?
Do you get a "rainbow square" in the corner of the screen?
Posted: Fri Jan 08, 2016 10:15 am
by hansotten
mba75 wrote:Hi there
What configuration? Installed device drivers? Remove those!
Your problem sounds like a bad power supply or SD card.
Posted: Fri Jan 08, 2016 1:25 pm
by mba75
I have tried this both With Ubuntu MATE and Noobs, also Others, I have tried out quite a fem distributions.
My power supply is a 5v 2,5-2,6A that Came With the rpi when I bought it.
The sd card i 16gb hc10.
To the Pi I have a Bluetooth keyboard/mouse, wifi dongle and USB-hub.
