USB power hub
Posted: Thu Jan 07, 2016 12:21 pm
by gychang
please recommend a USB hub (>4 inputs), that is powered can put out >2A for RPi2, thanks,
Re: USB power hub
Posted: Thu Jan 07, 2016 12:50 pm
by kusti8
I have this. Works very well. No problems.
http://www.amazon.com/ORICO-USB2-0-Adap ... rt+usb+hub
Re: USB power hub
Posted: Thu Jan 07, 2016 1:09 pm
by fruitoftheloom
kusti8 wrote:I have this. Works very well. No problems.
:?: is there a 500ma max draw on each port or is it less ?
Re: USB power hub
Posted: Fri Jan 08, 2016 12:04 pm
by kusti8
I don't know. I looked at the Amazon page but there is no info on this.
Re: USB power hub
Posted: Fri Jan 08, 2016 12:06 pm
by QuietZone
I have had excellent luck with this:
http://www.amazon.com/Plugable-7-Port-S ... le+usb+hub
(on a recommendation from this forum). It currently powers two Pis and a bunch of other stuff.
Re: USB power hub
Posted: Fri Jan 08, 2016 12:07 pm
by fruitoftheloom
OK thanks for responding.....
Re: USB power hub
Posted: Fri Jan 08, 2016 12:11 pm
by RaTTuS
http://www.amazon.co.uk/dp/B00PK1IIJY?psc=1
should do the trick #I've had very good results with anker hubs in the past I've not used this one
