Recommended Web Browser
Posted: Mon Jan 04, 2016 12:50 pm
by Spetmode
I am NOOBS to the Raspberry Pi :mrgreen: , and was wandering what browser was the best and fastest to use. Also do you think i should Raspbian or NOOBS as the OS?
Re: Recommended Web Browser
Posted: Mon Jan 04, 2016 2:29 pm
by Pithagoros
Noobs is a convenient way to set up your Raspberry Pi with Raspbian (or another choice of OS).
I personally prefer to install Raspbian directly, but I think Noobs is considered to be the way that beginners install Raspbian.
Your browser question does depend on which Raspberry Pi you have, and what you intend to do with it.
Posted: Mon Jan 04, 2016 2:36 pm
by DougieLawson
Coming from Windows you'll find that NOOBS or NOOBS lite (which is an installer not an OS) is the easiest way to get Raspbian running. It's designed for the new/novice users as it should just be a simple, download, unzip, copy to get the files needed on to your blank SDCard.
Since you've asked the question, you are the ideal candidate as a NOOBS user. If you've used Linux before you could consider going with the plain Raspbian image.
Posted: Tue Jan 05, 2016 10:57 pm
by Spetmode
Thank you guys for the help, this has helped me quite a bit
Posted: Wed Jan 06, 2016 1:44 pm
by hello world :-)
Spetmode wrote:I am NOOBS to the Raspberry Pi :mrgreen: , and was wandering what browser was the best and fastest to use. Also do you think i should Raspbian or NOOBS as the OS?
The best I have found so far is Epiphany Web Browser, but I'm sure there are better, faster browsers out there :)
Posted: Wed Jan 06, 2016 1:51 pm
by fruitoftheloom
Kweb minimal browser uses the same webkit engine as Epiphany :D
Posted: Sat Jan 09, 2016 2:33 pm
by gychang
chromium is best for me...
