Computerring123
WebIOPi installation
Fri Jan 01, 2016 1:21 pm
I can´t install WebIOPi to my raspberry.
Operation system is raspbian jessie.
When i type basic installation command it displays this :
[email protected]:~ $ sudo tar xvzf WebIOPi-0.7.1.tar.gz # (command)
tar (child): WebIOPi-0.7.1.tar.gz: Cannot open: No such file or directory
tar (child): Error is not recoverable: exiting now
tar: Child returned status 2
tar: Error is not recoverable: exiting now
So how to install webiopi?
danjperron
Re: WebIOPi installation
Fri Jan 01, 2016 1:28 pm
If you have a PI2B , you need to modified it!
change BCM2708_PERI_BASE to 0x3F000000
line 32 in
in WebIOPi-0.7.1/python/native/gpio.c
Computerring123
Fri Jan 01, 2016 1:47 pm
I have raspberry pi B+
Computerring123
Fri Jan 01, 2016 1:49 pm
So how to install webiopi to b+?
danjperron
Fri Jan 01, 2016 1:52 pm
Ok The B+ doesn't need to modify the code
Download it first
cd ~
wget http://sourceforge.net/projects/webiopi/files/WebIOPi-0.7.1.tar.gz
and then
cd WebIOPi-0.7.1
sudo ./setup.sh
danjperron
Fri Jan 01, 2016 2:07 pm
Also on Jessie you will need to enable the service
sudo systemctl enable webiopi.service
sudo systemctl start webiopi.service
Computerring123
Fri Jan 01, 2016 5:31 pm
Thx! it works.
Saixo
Thu May 12, 2016 11:25 pm
Hello.
1st thank u for the infos here :)
i can see the header now on my browser but when i click some gpio's it just does nothing, also not on the webpage. Do i need to allow GPIO control for webiopi with some tricks?
//edit: nevermind, it worked after reboot o.O
