jklondon
Cheap wifi temperature logger
Thu Dec 31, 2015 2:02 pm
Hi - looking to create a small cheap temperature logger that streams to the internet.
What components can I use to create this, ideally no soldering if possible?
JK
Re: Cheap wifi temperature logger
Thu Dec 31, 2015 5:13 pm
Common one is a DS18B20. You can use a solderless breadboard and some dupont wires to connect that to 3V3, GND and GPIO04 on your RPi.
AiGreek
Thu Dec 31, 2015 5:22 pm
DHT22 with python and SQLite (or MySQL)
morticiaskeeper
Thu Dec 31, 2015 8:56 pm
I use a couple of DS18B20 sensors on a Pi2, recording to a SQLite database. Then a cgi script to present and graph the data over the web.
It was all built and tested on a PiZero if you want to go smaller.
This is the instruction I followed
http://raspberrywebserver.com/cgiscript ... ogger.html
jklondon
Thu Dec 31, 2015 9:44 pm
Thanks - DHT22 seems way forward - found a good tutorial here https://www.youtube.com/watch?v=IHTnU1T8ETk although if someone knows a better one for beginner pls shout. I assume this could work on pi zero if I can find one!
morticiaskeeper
Fri Jan 01, 2016 7:08 pm
I'm sure that will work on the PiZero, but it doesn't seem to show how to stream it to the web.
The link I gave above logs the temperature to a SQLite database.
at the bottom of the page is another link which shows you how to read the database over the web.
