swilker
General Confusion net to Python
Mon Dec 28, 2015 4:09 am
Can some one explain to me why on post:
http://computers.tutsplus.com/tutorials ... -cms-20051
that I'm declaring
Motor1A = 16
Motor1B = 18
Motor1E = 22
is used to control a motor when I'm actually wired into 23,24,25 on the pi? that's wild
scotty101
Re: General Confusion net to Python
Mon Dec 28, 2015 2:19 pm
The pins on the Raspberry Pi's main connector is numbered from 1-40. These are the board pin numbers
These pins make available a set of GPIO pins, in your case your are using 16,18 and 22. These are the BCM pin numbers.
Abhiraj Tiwari
Mon Dec 28, 2015 5:38 pm
pxgator wrote:For getting started with Python here is a good place to start:
https://www.raspberrypi.org/documentati ... /README.md
If you like Arduino style coding here is a system that the Arduino
environment is based on and it works great with the RPI 2:
Thanks a lot pxgator
swilker
Wed Dec 30, 2015 12:31 am
Ok thanks, but is there a cross reference between the raspberry numbers and the GPIO numbers, how does one know?
Wed Dec 30, 2015 12:35 am
swilker wrote:Ok thanks, but is there a cross reference between the raspberry numbers and the GPIO numbers, how does one know?
http://pinout.xyz has an interactive pin number mapper. It does all three numbering schemes (board, BCM and WiringPi).
davidcoton
Wed Dec 30, 2015 12:37 am
Try this
Wow, three answers in three minutes!
