MartinPi
Can I partition my sd card for half os, half storage?
Mon Dec 28, 2015 12:02 am
Hi there, is this possible?
I have a 32gb micro sd card with full sd adaptor (so I can plug it into my iMac and install noobs).
Is it possible to partition the sd card so that half of the drive is FAT32 with the noobs install, and half just empty FAT32 for storage sharing. What I mean by storage sharing is a space on the drive that both the Pi and my computer can access when plugged in at a given moment.
Ie, take my sd card out my Pi, plug it into my Mac, add a document from my Mac and put it back into the Pi and access the document.
Raspberry Pi 3 32GB with 32-inch Monitor
Rasberry Pi Zero 32GB
Re: Can I partition my sd card for half os, half storage?
Mon Dec 28, 2015 12:34 am
You can't take the SDCard out while the RPi is booted from it (if it has the root fs). Your RPi will crash and you risk corrupting the filesystems on the card.
Use a USB memory stick to transfer files. It's easier and can be done without a reboot.
stderr
Mon Dec 28, 2015 12:47 am
MartinPi wrote:Ie, take my sd card out my Pi, plug it into my Mac, add a document from my Mac and put it back into the Pi and access the document.
Certainly you can format part of your sdcard in something that the Mac would prefer to be able to read. The main problem with dividing up a drive into a lot of chunks is that you might end up with a need for space in one chunk but the only available space is in another. Certainly it would seem that 16gig for the os should be enough.
solar3000
Mon Dec 28, 2015 12:51 am
Its a little complicated to resize it. I just picked up a 32GB card for $8 USD. That's slightly more than the pi zero.
Antikythera
Mon Dec 28, 2015 7:49 am
MartinPi wrote:Hi there, is this possible?
The issue with NOOBS is it creates its own partitioning scheme:
https://github.com/raspberrypi/noobs/wi ... -explained
RPi 4B 4GB (SSD Boot)..
