Re: Minecraft
Posted: Sat Nov 12, 2011 3:08 pm
by hwangs
Will the raspberrypi be able to run minecraft?
Re: Minecraft
Posted: Sun Jan 01, 2012 6:19 am
by qvinlove
If it can run a simple java runtime, it can run minecraft. There are plenty of java programs for arm and Linux, so yes, it can.
Re: Minecraft
Posted: Sun Jan 01, 2012 6:22 am
by Prometheus
I gather that there's a difference between "running" and "running well", though.
I'm pretty sure that Minecraft can be pretty heavy on multi-core x86 behemoths, after all.
Re: Minecraft
Posted: Sun Jan 01, 2012 4:53 pm
by mrmlk
Java runtime is not "simple" (look at the problems the three OSS attempts have had replicating the APIs). This is now not such a large issue as Java has been Open Source'd. Minecraft also uses a number of native components which would need to be compiled for Linux/ARM (lwjgl I think).
Nothing insurmountable I think.
You then the question of if the device has the grunt to run Minecraft. I’d guess if a Netbook can, the Pi would.
Re: Minecraft
Posted: Sun Jan 01, 2012 5:13 pm
by jamesh
I'm no Minecraft expert, just had to look it up on Wikipedia, but looking at the graphics, and the fact in runs in JAVA, I reckon its not going to be playable on a Raspi without decent GPU acceleration, and I'm not sure it would use it by default. Even with acceleration its going to be touch and go whether its playable.
Re: Minecraft
Posted: Sun Jan 01, 2012 5:26 pm
by Tomo2k
The PC version of Minecraft certainly used to struggle occasionally on >2GHz x86 machines, so I don"t think it is likely to be playable on a 700MHz ARMv6.
- I understand that Mojang have made some efficiency improvements since I last played the 1.8 beta, so it will be a better proposition now.
It was also *extremely* greedy for RAM – on my PC it tended to level out at 2GB of ram usage.
That said, they have produced portable versions so maybe if you ask nicely and get them enthusiastic about it they"ll make a Raspberry Pi version. I suppose that depends how much work it would be – and more importantly, how much fun!
Re: Minecraft
Posted: Sun Jan 01, 2012 5:38 pm
by Benedict White
I have seen the graphics for minecraft, and am mystified why someone would actually play the game.
Re: Minecraft
Posted: Sun Jan 01, 2012 5:47 pm
by nvoid82
Most of the memory sucking done by minecraft has been because of mods or memory leaks( which seem to be a lot less frequent in the full version). It can run stable (Without mods) on only 256m ram, and without sound on 128m. The main bottlenecks seem to be graphics and storage.
Re: Minecraft
Posted: Sun Jan 01, 2012 6:25 pm
by Tomo2k
The amount of fun in a game has nothing to do with the graphics!
Look at Nethack! A better comparision might be some of the newer 3D Sonic The Hedgehog which generally tanked, compared to the great platformer it was on the Megadrive.
Minecraft is essentially a really open sandbox game. If you want a storyline, or even clear goals then it's not for you.
Re: Minecraft
Posted: Sun Jan 01, 2012 11:54 pm
by foo
"I have seen pictures of Lego bricks, and am mystified why someone would actually play with them instead of cool-looking action figures."
Re: Minecraft
Posted: Sun Jan 01, 2012 11:59 pm
by Benedict White
Scratches head looking for good riposte....
None found.
Re: Minecraft
Posted: Tue Jan 03, 2012 4:35 am
by Prometheus
Putting aside whether or not it will run, I just remembered that there's another issue with Minecraft, here.
Does the RPi's graphics driver support full OpenGL, or just OpenGL ES, or similar? The reason I ask this is because the graphics library used by Minecraft doesn't yet support OpenGL ES, just "full" OpenGL, which may pose a problem. (Just something I've picked up from questions about running Minecraft on the Pandora. )
Re: Minecraft
Posted: Tue Jan 03, 2012 5:51 pm
by Tomo2k
Good point.
It supports OpenGL ES 2.0, and not the 'desktop' OpenGL.
Re: Minecraft
Posted: Tue Jan 03, 2012 6:00 pm
by jamesh
There's not a huge difference, the Quake demo was ported from GL to GL ES. Not sure how long it took though.
Re: Minecraft
Posted: Tue Jan 03, 2012 7:41 pm
by mightygoose
What about pocket minecraft... surely the Android version is alot closer to home than the windows version?
Re: Minecraft
Posted: Wed Jan 04, 2012 1:06 pm
by pocketmoon
I have to say watching my 12 year old playing Mineraft was a bit boggling. I guess My folks had the same look when I was sat at my BBC Micro playing elite ...
But just before Christmas he asks, 'Dad, can I learn java'! He's one of the current generation suffering the 'IT' lessons in schools and I've been trying to get him interested at a more traditional level. His sudden interest in java came about because of Minecraft - he want's to write mods for it. So we install Eclipse and after about 10 minutes of me trying to explain object orientated code he's off. The code is well structured, object orientated and easy to read. I also told him he could earn £500 per day with top Java skills
He went back to school yesterday and I told him to ask his IT teacher if they know how to program a computer >:)
So +1 for Java on a Raspberry.
