So I wasn't thinking straight and added an 'exit 0' to the end of my ~/.bashrc
Assuming you're using the standard Raspbian stuff: the file manager has an option to show hidden files (can't remember in which menu it is).k den wrote:I wasn't able to find it in the file manager (since it is a dot file.) Thanks!
Yes, unless you made some more interesting edits to the filek den wrote:Found it! Thanks so much!So once I save the file with leafpad (without exit 0) and reboot, the terminal should open, correct?
