The RPi 2 I bought directly after release from pimoroni has started behaving weirdly.
It has black camera and screen latches instead of white.
Anyone had the same experience?
My other 4x RPi 2 (white latches) are 100% stable.
Early RPi 2 randomly segmentation faults process
https://github.com/tinspin/rupy - A tiny Java async HTTP application server.
Re: Early RPi 2 randomly segmentation faults process
Define 'weirdly'...
- RaTTuS
- Contact: Twitter YouTube
what does
can you upload a video to you tube to explain better
are all the cables plugged in fully etc ...
when did iit stop working proper , what had you done
mean
Covfefe
Covfefe
So the white latches are just to point out it's one of the first RPi 2 out of the factory. And not the same factory as todays RPi 2, the metal on the HDMI port is different too (matte aluminium instead of dark shiny). Edit: Precisely AndyD.
I have changed nothing, it has been running flawlessly for 1 year 24/7 until two weeks ago when it had one core running 100% on a strangely simple stack trace place, I shrugged it off as my fault. But then yesterday and today it has crashed the process with segmentation fault on other seemingly common stack trace places.
I'm suspecting something broke with the RAM when I had power outages a month ago, 3 in a row.
The differences in latch colour and HDMI port etc may be to do with the Country of manufacture.
Exactly, so I'm trying to figure out if it's a one time freak occurrence or if others with early RPi2 from the white black latch factory are seeing failures too after 1 year of 24/7 operations.
I'm a white latch kind of guy. Never seen a problem with random failure cropping up.
Have you been keeping your OS updated? Things will have been changing, perhaps introducing a problem.
Have you tried swapping the power supply, just to eliminate that as a possible cause?
Does this problem only show up when running some particular program?
What actually are the stack traces ?
I meant black, white latches are 100% stable for me too, typo above...
I have not changed anything.
Power supply is the same as the white latches:
The issue stack traces are not in my code but in Java core classes, in different places every time.
I'm pretty sure the hardware on this RPi 2 is failing.
- RaTTuS
dunno - try a fresh raspbain
then try
sudo apt-get memtester
sudo memtester
then try
sudo memtester
Covfefe
Covfefe
bullen,
That is a neat cluster you have there.
I'd certainly want to be testing with memtester and such as suggested. It'd start with a new SD card and new OS image just to eliminate those as possible sources of trouble.
Ah, now I see your problem. ..... Only joking.The issue stack traces are not in my code but in Java core classes...
Might it be worth underclocking it a wee bit to see if stability returns?
- RaTTuS
nogregeric wrote:Might it be worth underclocking it a wee bit to see if stability returns?
first thing is
viewtopic.php?f=63&t=129721#p866727
anything else and you cannot be certain
Covfefe
Covfefe
Hm, so it's not memory:
Maybe it's the SD card? But I think I'll just buy a new RPi 2 and a new SD card and cross match them if it fails again...
Well see...
It must be the CPU then... how does one verify that?
pagesize is 4096
pagesizemask is 0xfffff000
want 900MB (943718400 bytes)
got 900MB (943718400 bytes), trying mlock ...locked.
Loop 1/1:
Stuck Address : ok
Random Value : ok
Compare XOR : ok
Compare SUB : ok
Compare MUL : ok
Compare DIV : ok
Compare OR : ok
Compare AND : ok
Sequential Increment: ok
Solid Bits : ok
Block Sequential : ok
Checkerboard : ok
Bit Spread : ok
Bit Flip : ok
Walking Ones : ok
Walking Zeroes : ok
8-bit Writes : ok
16-bit Writes : ok
Done.
Well see...
By all means get a new Pi and SD to get things working.
It would be nice to get to the root cause of the problem though.
I'm betting on, SD card, OS image, power supply...(oh and Java
You could always send me that suspect Pi. For analysis you understand...
Just to follow up now I'm suspecting it is the SD card after all.
When I had the power outages (not good for SD cards BTW) the following script was not run:
swapoff -a
sysctl -w vm.swappiness=0
Basically maybe the swap partition has taken a hit after being power cycled in use after the first failure?
And maybe that's where the problems sneak in... easy way to test is to turn off swap and then the system should work...
But better is to buy a new SD card and make sure!
swapoff -a
