bonjurkes
Question about Pi
Sun Jul 29, 2012 11:26 pm
Hey,
I just read faq, read some articles and decided to order pi :) But I have some questions to ask, probably easy ones.
1-) As power source, can I use my cell phone charger's micro usb cable with wall socket connector? It says on it output : 5V 1A. Will it be enough for pi, or too much or less?
2-) I am planning to use pi for downloading mainly, just for start. I wont waste it only with downloading tho :) Can I connect it some 320 gb disk to use for download files into it? Or insert some usb sticks 8 gb for storage?
3-) Can I install some download software and make it save files into external disk that i will connect from usb?
4-) Can I install vnc on raspberry pi to connect from my windows device? Or only way is using keyboard and mouse from usb?
5-) Do I need to order some gpio cable for starting? I will use ethernet connection, hdmi cable and usb ports with sd card.
thanks a lot for answers
JeremyF
Re: Question about Pi
Sun Jul 29, 2012 11:54 pm
bonjurkes wrote:Hey,
1) Probably, assuming the voltage is stable enough. It probably will be.
2)Yes, powered hub needed for hard drive though (but flash drive should be fine without)
3)Yes
4)You can install a VNC server
5)No GPIO cable needed to get started
{sig} Setup: Original version Raspberry Pi (B, rev1, 256MB), Dell 2001FP monitor (1600x1200), 8GB Class 4 SD Card with Raspbian and XBMC, DD-WRT wireless bridge
bonjurkes
Sun Jul 29, 2012 11:59 pm
Forgot to ask one more, can I install programs etc into the sd card that will contain debian image, or nothing else than image can be installed on sd card, and need to connect a drive (hard drive, usb etc)
AndrewS
Mon Jul 30, 2012 1:31 am
Most of your questions are answered on the Wiki :)
http://elinux.org/RPi_Hardware_Basic_Se ... _Will_Need
http://elinux.org/RPi_Tutorials
http://elinux.org/RPi_Guides
Please feel free to ask more questions though if you still can't find what you're looking for!
alexeames
Mon Jul 30, 2012 5:26 am
1 = 2 = 3 = 4 = YES
5 = NO
And yes, you can install programs on the SD card.
Alex Eames RasPi.TV, RasP.iO
holmez
Mon Jul 30, 2012 7:29 am
bonjurkes wrote:Forgot to ask one more, can I install programs etc into the sd card that will contain debian image, or nothing else than image can be installed on sd card, and need to connect a drive (hard drive, usb etc)
Yes you can.
How much extra depends on the size of the SD card. A 2Gb card has a very limited amount of space remaining.
