fruit-uk
Re: Want solderless headers for the Pi0?
Fri Jan 29, 2016 7:11 pm
Deltron probes can be used on the outer pins, many similar available on ebay, search hook probe
davidcoton
Fri Jan 29, 2016 8:03 pm
Different supplier, different colour( but two colours in the pack!!), lower price!!!
http://www.ebay.co.uk/itm/200Pcs-Green- ... 1676543991
morphy_richards
Fri Jan 29, 2016 8:19 pm
Doing a general search for PCB test pins also yields potentially useful results eg.http://www.toby.co.uk/datasheets/sectio ... 2015095007
mattmiller
Fri Jan 29, 2016 9:36 pm
Can't see anything suitable there - even the eye type one would probably short out to the next pin
morphy_richards
Fri Jan 29, 2016 11:13 pm
mattmiller wrote:Can't see anything suitable there - even the eye type one would probably short out to the next pin
Probably right but I was quite interested in the "TEST-3 Series Low Cost Wire Form Test Points". The loop is 2.7 mm diameter so would not reach the next pin. It doesn't say what the gap is between the two legs of the spring but it looks to be less than the diameter of the loop. At best I reckon it would be wobbly and temporary with a lifespan of a few minutes.
rurwin
Mon Feb 01, 2016 11:46 am
Another option, but rather expensive: http://uk.rs-online.com/web/p/pcb-headers/6935416/
B.Goode
Mon Feb 01, 2016 12:09 pm
rurwin wrote:Another option, but rather expensive: http://uk.rs-online.com/web/p/pcb-headers/6935416/
Good spot! Might be worth a try...
(The housing looks as though it will obscure the mounting holes on the PiZero - probably not a major concern - but I would also be worried about fouling on the microSD slot and the tiny smd components half-way along the SoC chip.)
I don't think the price is that bad for someone who does not want to consider soldering a connector for whatever reason - quite comparable to the price of the HDMI and microUSB adapters that most people will need.
morphy_richards
Mon Feb 01, 2016 8:10 pm
And another solution from the magpi...
blaablaaguy
Tue Feb 16, 2016 8:39 pm
Apparently those things can damage the pcb you insert them in.
This signature intentionally left blank.
rpdom
Tue Feb 16, 2016 8:48 pm
morphy_richards wrote:And another solution from the magpi...
Is that a prototype Zero in that picture? It doesn't seem to have the composite video holes.
rurwin
Wed Feb 17, 2016 12:37 am
blaablaaguy wrote:Apparently those things can damage the pcb you insert them in.
Yes. They're good for one insertion but anything like this is likely to damage the through-hole plating if not the PCB itself.
texy
Wed Feb 17, 2016 2:15 pm
I was going to suggest push-fit connectors, however they usually require quite some force to fit them, depending on the number of pins.
Texy
chrisoh
Wed Feb 17, 2016 2:22 pm
I'm curious about this too :)
Raspberry Pi 3 model B Idle @ 250mA
  • HDMI +200mA
  • Minecraft 1.9 Server +100mA
  • 2.4Ghz dongle +20mA
texy
Wed Feb 17, 2016 2:28 pm
Life is too short. As it was from the magpie mag then it was probably a pre-production prototype used for the article prior to publication.
Texy
rurwin
Wed Feb 17, 2016 2:41 pm
Way outside the box here, I'm thinking that blutak is fine in the very short term but it's too soft. The wires will migrate through it and stop making contact. What you need is something with a little spring to it.
And then I thought of ear-plugs. As in these things: http://uk.rs-online.com/web/p/ear-plugs/7858516/ They are highly mouldable but spring back to shape. I doubt you could poke them into the hole along with the wire though. Maybe cut a bit off? Still fiddly. Maybe part of the solution though.
And then I thought of dental points: http://www.ukdentalsupplies.com/cgi-bin ... aGP10_2d90
These are tapering cylinders of latex* and absurdly cheap (£6 for 120) that you could use like matchsticks to jam a wire in a hole. They taper from well under 1mm to something over 1mm. They've got a reasonable strength along the axis so they should be usable. I'm sure your dentist could let you have a few to experiment with.
* https://en.wikipedia.org/wiki/Gutta-percha
mattmiller
Wed Feb 17, 2016 6:03 pm
Like idea of a jamming mechanism
Its made me thing about just super-gluing an extended header (pushing pins through from underneath)
Going to see if its reliable enough to plug an addon-board and see if it works!
rurwin
Wed Feb 17, 2016 8:38 pm
I'm not convinced. There's no force pushing the wire against the hole and a good chance it will be pulled between the two by capillary action.
blaablaaguy
Wed Feb 17, 2016 9:04 pm
I think thes guys have them (solderless headers): http://www.toby.co.uk/index.aspx
Theyre not on their site tho, so youl have to email them or something.
mahjongg
Thu Feb 18, 2016 12:19 am
rurwin wrote:These might be worth experimenting with: 200 x Ted Ceramic Bead Ring Head Gold Tone Copper PCB Test Pin Terminals
I have no idea if they would fit or make a secure connection.
Worth a punt will order some, thank you :)
these are for soldering into test points (holes) they are NOT solder less headers, which are stupid by the way.
Just learn to solder!
Adrianfu
Thu Feb 18, 2016 1:26 am
rurwin wrote:If soldering headers onto thirty Pi Zeros has you in a cold sweat, contact your local Amateur Radio club. There's at least one in every town and they are chock-full of lovely people who will volunteer to do the job for free.
OTOH, for one-off when you haven't got a soldering iron, then solderless headers are a good option to have.
If I was closer I would do it for him
Adrian VK4KL
blaablaaguy
Sat Feb 20, 2016 10:29 pm
I got free samples! Three of each header type! Unfortunately they weren't realy worth it. Too tight or something, didnt end up using them. Oh well- at least they were free :)
ProperNoun
Wed Feb 24, 2016 10:11 pm
If you can find them, something like these might work: http://www.ebay.com/itm/1PC-NEW-10PIN-S ... 1511412820
If anyone tries them out, let us know.
