KenoRosarioPH
Windows built pascal program to my RPI
Sat Dec 05, 2015 1:02 pm
Good day Forum! I'm quite confused about all the articles that concerns my problem with my pascal program(im using lazarus IDE). I have my program that works fine in windows platform, how can i compile and run it with my RPI. I have read various articles about installation of fpc and lazarus to my RPI and i can't get it it to work. Im having a lot of trouble with cross-compilers.
Jim Manley
Location: SillyCon Valley, California, and Powell, Wyoming, USA, plus The Universe
Re: Windows built pascal program to my RPI
Sat Dec 05, 2015 4:58 pm
KenoRosarioPH wrote:Good day Forum! I'm quite confused about all the articles that concerns my problem with my pascal program(im using lazarus IDE). I have my program that works fine in windows platform, how can i compile and run it with my RPI. I have read various articles about installation of fpc and lazarus to my RPI and i can't get it it to work. Im having a lot of trouble with cross-compilers.
Hi Keno - you'll need to be a lot more specific about what problems you're having starting with a link to your source code, then posting a copy of the errors you're getting here (use the Code tag button just above the post editor used to create a post, so it will be easy to read). First, can you successfully compile and run the testrpi.pas program at https://github.com/rudiratlos/rpi-hal ? Can you run any other programs written using Lazarus on Windoze that run fine there, and get them to run on the Pi version? Start with a Hello World program and work up to more complex examples from tutorials, if needed.
KenoRosarioPH
Sun Dec 06, 2015 2:18 am
Thank you for the concern sir, but i think i got my post too confusing. What i really want to know is how will my RPI run my Pascal program which was built on my Windows 10 (w/ x64 fpc). My program works fine on my Windows 10 but as i copied my project files to my RPI (w/ lazarus) i knew that my program will not work since it was built on a different platform. And i am very confused all about the installation article of lazarus on RPI. Ty sir Good day
ghans
Sun Dec 06, 2015 3:33 pm
What happens if you transfer the project to the Pi and then build it on the Pi ?
ghans
KenoRosarioPH
Tue Dec 08, 2015 8:46 am
ghans wrote:What happens if you transfer the project to the Pi and then build it on the Pi ?
ghans
It is all well now, but i need to remove some codes in it inorder for it to run. It just takes time to build it. Thanks sire
ghamm
Sat Dec 12, 2015 10:43 pm
you might check out our group on facebook. We are Pascal Raspberry enthusiasts
https://www.facebook.com/groups/RaspberryPascal/
