Reasonable
Connecting multiple SDA SCL Devices
Fri Dec 04, 2015 10:16 pm
Is there such a thing (board/controller) that would allow connecting multiple sda / scl devices to raspberry pi?
thanks!
mikronauts
Re: Connecting multiple SDA SCL Devices
Fri Dec 04, 2015 10:25 pm
I2C (which is the SDA & SCL signals, plus ground) is a multi-chip bus
You have to:
- watch the total length of the cable
- watch the voltage of the chips
Google "how to use i2c"
There are other limits - for example, some I2C devices only have one possible address, so you cannot have more than one per bus. Others let you select from a number of addresses (2/4/8 usually).
For the devices that only have a single address, you can use an I2C multiplexer, which acts like a switch, selecting between 4 to 8 sub-busses, which can have independent voltages. You can use these multiplexers to connect I2C devices which only have one address.
Reasonable wrote:Hi,
thanks!
ric96
Sat Dec 05, 2015 5:33 am
thanks!
Also watch the voltage, some run at 5v but the pi can only handle 3.3v. you will need voltage level converters.
My apologies for shameless YouTube Plugs...
youtube.com/sahajsarup
twitter @sahajsarup
skype srics1996
e-mail: [email protected]
Blog: http://www.geektillithertz.com/wordpress
Web: http://www.geektillithertz.com
hampi
Sat Dec 05, 2015 9:33 am
Here is an example what I have done for slow I2C
https://github.com/oh7bf/RPiAOneI2cSens ... ensors.pdf
