Palmpje
Raspberry Pi Zero overclocking
Fri Dec 04, 2015 9:51 am
I have browsed trough the internet, but yet can't find anybody that has does the trouble to push the zero to the edge of stability. I would like to know if the zero is a better overclocker then the standard product. This has ignite my interest because I could push my 700 mhz raspberry pi b up to 1100mhz. This was the border of stability. The zero however has been launched as a 1000 mhz product. Could this mean it can actually be clocked higher when changing the config file above "Turbo" values or not?
Could anybody give me some advice? Maybe anybody has already tried to find the frontiers of the stability of this product?
Thank you very much in advance
Kind :P Regards
Palmpje
Palmpje
Re: Raspberry Pi Zero overclocking
Fri Dec 04, 2015 12:06 pm
http://raspberrypi.stackexchange.com/qu ... -of-pizero
This source is now actually stating that there is a bug in the zero rendering overclocking impossible.
They are stating this would be corrected in the next batch.
Hopefully this is true, as I plan to overclock it.
gregeric
Fri Dec 04, 2015 12:28 pm
See http://forum.kodi.tv/showthread.php?tid ... pid2171907
It appears that the silicon is now being produced consistently such that there so few parts rejected when they test them at 1GHz that they can afford to toss them. It implicitly does not mean that you can overclock in excess of 50% as before on the 700MHz rated parts (that was always pot luck), but the upper limit may be the same, with rare parts getting to 1200MHz. So maybe a 20% overclock if you are the lucky owner of fast silicon, more likely hardly any worthwhile overclock at all
hansotten
Fri Dec 04, 2015 12:34 pm
Palmpje wrote:http://raspberrypi.stackexchange.com/qu ... -of-pizero
To prevent misunderstandings:
Not a bug in the Zero, but in the overclocking sw. Fixed in next release, not next batch of the Zero.
Quoted from the blog comment by SImon Long:
On Pi Zero, you should just leave overclocking set to “None” (which selects the default clock speeds set for the device in the firmware, i.e. 1GHz on the Zero) – all the other options will actually slow your Pi Zero down! This will be corrected in the next release – Pi Zero basically comes out of the box running as fast as it is safe to run it.
It runs a 1GHz!
http://duinorasp.hansotten.com for Raspberry Pi and Arduino and ESP8266
http://retro.hansotten.nl for retrocomputing with the 6502 cpu
Palmpje
Sat Dec 05, 2015 10:33 am
Thanks everybody for the replies. I understand that potential overclock possibilities could be in pair with already existing Models, with only a higher official released frequency and less potential headroom for overclocking. This however is not sure. I can't wait to get my hands on the next batch to try to squeeze 1200 or 1200+ stable MHz out of the "5 dollar".
If the bug is not hardware related, but sw related like mentioned, what does this actually mean?
Thank you for the highly appreciated replies. I believe there is a lot of knowledge on this quality raspi forum!
Sat Dec 05, 2015 11:46 am
A software bug can be fixed and an upgrade released for you.
A hardware bug in the chip itself world be, well, hard. A permanent unfixable "feature" of your Pi.
Jim Manley
Location: SillyCon Valley, California, and Powell, Wyoming, USA, plus The Universe
Sat Dec 05, 2015 5:17 pm
Note that the upper limit for overclocking varies from device to device, and you will have to go through hundreds, probably thousands, maybe even more, to find one that will reliably go to 1.2 GHz. It's a random distribution, with a relatively narrow "bell curve" now, as they've tweaked the manufacturing process to yield about as many higher-clocking devices as it's ever going to produce. Good luck collecting all of those Zeroes when demand is so extremely high, and will likely remain so until the Foundation pulls another rabbit out of its HAT!
Palmpje
Sun Dec 06, 2015 8:49 am
Is there anybody that knows when the next software will be available? Are we talking about a new raspbian release? Or is this not a major but small update that will be released probable soon?
Thanks!
Sun Dec 06, 2015 9:22 am
It'll probably be both - a software update that can be installed with "sudo apt-get update" then "sudo apt-get upgrade", and soon after that an updated release of Raspbian. Either method will work, so there will be no need to wipe your system and start again if you don't want to.
Palmpje
Wed Jun 01, 2016 9:58 am
Any progress on this guys? (and girls :D )
texy
Wed Jun 01, 2016 10:34 am
Really if the Zero is not quick enough then you need a Pi3 ;)
The Zero is already running at 1Ghz. I'd be surprised if it'll go much higher, reliably, and repeatably.
Texy
dom
Wed Jun 01, 2016 10:49 am
hansotten wrote: To prevent misunderstandings:
Just to clarify this is purely an issue with raspi-config (and the GUI Pi config utility which uses raspi-config).
You are free to manually edit config.txt. "arm_freq=1100" will work just as it always has in the past.
wouterds
Mon May 29, 2017 1:27 pm
dom wrote:You are free to manually edit config.txt. "arm_freq=1100" will work just as it always has in the past.
And is that supposed to work just like that? I ended up with a Pi Zero (latest revision, Pi Zero W) that doesn't boot anymore ¯\_(ツ)_/¯..
klricks
Mon May 29, 2017 1:36 pm
No amount of OC is guaranteed to work. You need to get a handful of SD cards and experiment until you find what works with your RPi.
Unless specified otherwise my response is based on the latest and fully updated Raspbian Stretch w/ Desktop OS.
PiGuy05
Tue Oct 03, 2017 1:13 am
Can you over clock a pi zero w? (sorry for not making a new thread) My RPI0W runs at 700 MHz. (as does all zero w I assume) Also is there going to be an update to the raspi-config to allow for zero w to be OC without editing the config.txt?
dom
Tue Oct 03, 2017 10:35 am
It runs at 700MHz when idle and 1000MHz when busy (the core is above 50% utilised).
PiGuy05
Wed Oct 04, 2017 4:53 pm
So at 100% load it runs at 1.2 ghz? edit: I see so it runs at 1000 mhg when over 50 load. Thanks
HermannSW
Wed Oct 04, 2017 6:54 pm
I did not know on the possibility of overclocking Pi Zero because I relied on the raspi-config message that overclocking is not possible.
Now I added "arm_freq=1100" as proposed to /boot/config.txt and rebooted:
[email protected]:~ $ cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq
700000
1100000
The first frequency was reported without activity (as told above). The second while running simple load in 2nd ssh session:
[email protected]:~ $ for((i=0; i<10000; ++i))
> do
> echo -n ""
> done
But I would be sceptical based on my Arduino Due posting "Overclocking Due over 102MHz gives nothing :-(":
https://forum.arduino.cc/index.php?topic=407592.0
Arduino Due default CPU frequency is 84MHz, and you can overclock to well over 200MHZ, but that has no measurable effect above 102MHZ. So overclocking for at least Arduino Due is not worth the effort for me.
Hermann.
Unchanged default Arduino "Blink" example run on three DUEs:
https://www.youtube.com/watch?v=iuj38HiWcXY
bookmark list: https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://github.com/Hermann-SW/fork-raspiraw
https://github.com/Hermann-SW/userland
https://twitter.com/HermannSW
HermannSW
Wed Oct 04, 2017 7:45 pm
I did test overclocking with 1100/1150/1200 compared to default (1000) with bottom simple for loop time test:
[email protected]:~ $ gcc -pedantic -Wall -O6 million.c -o million
With default 1000MHz CPU frequency:
[email protected]:~ $ ./million
min=3511us, avg=3574us, max=5236us
min=3512us, avg=3577us, max=5264us
min=3511us, avg=3581us, max=5449us
With 1100MHz:
min=3191us, avg=3256us, max=5168us
min=3191us, avg=3257us, max=5180us
min=3191us, avg=3258us, max=5183us
This seems to make really sense:
[email protected]:~ $ bc -ql
3577/3257
1.09824992324224746699
1100/1000
1.10000000000000000000
But with 1200 I did not get login, neither over ssh nor on HDMI monitor (I connected that in order to see the boot messages).
Even worse with 1150, after a lot of normal boot messages I saw some hex dumps(?) and a lot of kernel messages, and HDMI display was totally crazy.
Hermann.
[email protected]:~ $ cat million.c
#include <time.h>
#include <sys/time.h>
#include <stdlib.h>
#include <stdio.h>
#include <unistd.h>
#include <math.h>
#define N 1000
int main(int argc, char **argv)
  struct timeval start, end;
  int i,j,k,mi=999999999,ma=0,su=0,t;
  for(k=0; k<N; ++k)
    gettimeofday(&start, NULL);
    for(i=j=0; i<1000000; ++i) { j += i; }
    gettimeofday(&end, NULL);
    t= (end.tv_sec * 1000000 + end.tv_usec)
       - (start.tv_sec * 1000000 + start.tv_usec);
    mi = (t<mi) ? t : mi;
    ma = (t>ma) ? t : ma;
    su += t;
    printf("\r%dus (%d)           ", t, j);
  printf("\rmin=%dus, avg=%dus, max=%dus        \n",mi,su/N,ma);
  return 0;
cookrx7
Tue Apr 17, 2018 8:48 pm
Thank you Hermann! Very useful utility.
