Stoop
Can't update to latest Raspbian
Wed Dec 02, 2015 7:42 pm
I was looking at https://www.raspberrypi.org/blog/latest-raspbian-update and thought, yes I'll have me some of that, but none of my sudo apt-get commands will work.
First my sudo apt-get update gives me this ...
Hit http://mirrordirector.raspbian.org wheezy Release.gpg
Hit http://archive.raspberrypi.org wheezy Release.gpg
Hit http://raspberrypi.collabora.com wheezy Release.gpg
Hit http://mirrordirector.raspbian.org wheezy/main armhf Packages
Hit http://archive.raspberrypi.org wheezy/main armhf Packages
Hit http://raspberrypi.collabora.com wheezy/rpi armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/contrib armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/non-free armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/rpi armhf Packages
Ign http://archive.raspberrypi.org wheezy/main Translation-en_US
Ign http://raspberrypi.collabora.com wheezy/rpi Translation-en_US
Ign http://mirrordirector.raspbian.org wheezy/contrib Translation-en_US
Ign http://mirrordirector.raspbian.org wheezy/main Translation-en_US
Ign http://mirrordirector.raspbian.org wheezy/non-free Translation-en_US
Ign http://mirrordirector.raspbian.org wheezy/rpi Translation-en_US
Reading package lists... Done
Then my sudo apt-get dist-upgrade gives me this ...
Building dependency tree
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
So, nothing upgraded and when I try to install the individual packages, eg sudo apt-get install nodered I get ...
E: Unable to locate package nodered
What am I doing wrong?
Re: Can't update to latest Raspbian
Wed Dec 02, 2015 7:52 pm
Stoop wrote:I was looking at https://www.raspberrypi.org/blog/latest-raspbian-update and thought, yes I'll have me some of that, but none of my sudo apt-get commands will work.
afaiaa the update is for Raspbian Jessie which is the current stable release
Retired disgracefully.....
kusti8
Wed Dec 02, 2015 7:56 pm
You need to do a special procedure or just start fresh:
viewtopic.php?f=66&t=121880
Wed Dec 02, 2015 8:12 pm
You need to upgrade to Jessie to get NodeRED. It may be easier to build a fresh SDCard with a new download of Raspbian or NOOBS.
This is a doctor free zone.
borpin
Sat Dec 05, 2015 1:25 pm
I have a minimal install of Jessie and I am getting this "Unable to locate package nodered" error as well.
Sat Dec 05, 2015 1:36 pm
borpin wrote:I have a minimal install of Jessie and I am getting this "Unable to locate package nodered" error as well.
If you install the latest full Raspbian Jessie Standalone it will solve your issue
https://www.raspberrypi.org/downloads/raspbian
borpin
Sat Dec 05, 2015 1:45 pm
Yes but I do not want the full (bloated) version. What I have works really nicely (it is a fresh Jessie minimal install via the repository).
What I'd like is Node-red but it is not in the repository (AFAICS) so the command in the blog post does not work.
Sat Dec 05, 2015 1:54 pm
borpin wrote:Yes but I do not want the full (bloated) version. What I have works really nicely (it is a fresh Jessie minimal install via the repository).
Did you ?
apt-get update
http://nodered.org/docs/hardware/raspberrypi.html
dgordon42
Sat Dec 05, 2015 3:08 pm
Node-red is available in Raspbian Jessie
 apt-cache policy nodered
nodered:
  Installed: (none)
  Candidate: 0.12.1
  Version table:
     0.12.1 0
        500 http://archive.raspberrypi.org/debian/ jessie/main armhf Packages
Dave.
borpin
Sat Dec 05, 2015 5:39 pm
Ok so it seems you are pointing to http://archive.raspberrypi.org/debian/d ... f/Packages which does have nodered listed
My apt sources.list is pointing to http://mirrordirector.raspbian.org/rasp ... f/Packages which does *not* have nodered listed
Am I right in thinking the repositories are out of step. Which is the right one to use?
Sat Dec 05, 2015 6:06 pm
borpin wrote:Am I right in thinking the repositories are out of step. Which is the right one to use?
Both.
The raspbian one contains the equivalent of the Debian repository. i.e. the majority of the software.
The raspberrypi one contains software that has been written or modified specifically for the Pi.
You'll usually find the raspbian one listed in /etc/apt/sources.list, and the raspberrypi one in /etc/apt/sources.list.d/raspi (or something like that, I can't check at the moment).
dgordon42
Sat Dec 05, 2015 6:26 pm
My /etc/apt/sources.list, from a clean install of Raspbian Jessie:
deb http://mirrordirector.raspbian.org/raspbian/ jessie main contrib non-free rpi
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
#deb-src http://archive.raspbian.org/raspbian/ jessie main contrib non-free rpi
My /etc/apt/sources.list.d/raspi.list
deb http://archive.raspberrypi.org/debian/ jessie main ui
deb-src http://archive.raspberrypi.org/debian/ jessie main ui
Hope this helps,
Dave.
borpin
Sun Dec 06, 2015 1:22 am
Ok thanks. What I had missed was that these were different domains. My sources.list has 2 entries;
deb http://mirrordirector.raspbian.org/raspbian jessie main firmware
deb http://archive.raspberrypi.org/debian wheezy main
It is obvious now that the second needs to point to jessie not wheezy!
Thanks for your help. I have it installed.
