Page 16 of 23
Re: Berryboot v1.1 - Boot menu / OS installer
Posted: Sat Jan 12, 2013 3:28 am
by Max
antonholmstedt wrote:
sudo mksquashfs /mnt 2012-08-08-wheezy-armel.img -comp lzo -e lib/modules
Can't find a SQUASHFS superblock on 2012-08-08-wheezy-armel.img
Should I just force it?
Nah, better not.
Provide a new name for the new image, and do not enter the same name as the source image.
E.g.
sudo mksquashfs /mnt 2012-08-08-wheezy-armel-for-berryboot.img -comp lzo -e lib/modules
Posted: Sun Jan 13, 2013 12:22 am
by antonholmstedt
Nah, better not.
E.g.
Thanks for the help, I can now start the soft float debian, and have installed Mopidy so I can play spotify directly from my RPi and using my android phone as remote
Posted: Sun Jan 13, 2013 7:14 pm
by Astro
Is there a version of Adafruit’s Occidentalis for Berryboot?
Posted: Sun Jan 13, 2013 10:27 pm
by joemouth
Unfortunately BerryBoot will not give me the choice to install the images from an USB stick instead of downloading.
I copied the images to the FAT32 formatted 8GB stick, but BerryBoot always starts downloading.
How can I change this? Thanks.
Posted: Sun Jan 13, 2013 11:20 pm
by Max
joemouth wrote:Unfortunately BerryBoot will not give me the choice to install the images from an USB stick instead of downloading.
Hold down your mouse button over the "Add OS" button, in the main window.
There is a screenshot somewhere on the first page of the thread.
Posted: Mon Jan 14, 2013 4:14 am
by Psychaotix
Just a FYI from me.
I've managed to get my Pi booting from a 512mb SD card, courtesy of the "install to USB" function in Berryboot. Right now, only /boot is sitting on the SD card, with the / partition sitting on an 8Gb USB stick.
This would be of some help to those with some low capacity SD cards they wouldn't mind using up, but remember that the mileage you get will likely vary.
Berryboot also makes it easy to setup WiFi so that you can access the network fairly easily.
Posted: Mon Jan 14, 2013 7:06 am
by joemouth
That's it ! Great and thx
Posted: Mon Jan 14, 2013 7:46 pm
by isimmons
Well this is just perfect!
I have 1GB SD cards laying around but nothing bigger. Now I can go ahead and get started playing with my pi today!
Thank you!
Posted: Mon Jan 14, 2013 11:57 pm
by joemouth
Is there any documentation of the advanced configuration of BerryBoot?
Details for config.txt and cmdline.txt?
Posted: Tue Jan 15, 2013 12:07 am
by Max
joemouth wrote:Details for config.txt and cmdline.txt?
config.txt
http://www.elinux.org/RPiconfig
Do not touch the kernel and initramfs lines.
cmdline.txt
All parameters must be on a single line separated by spaces.
Berryboot specific options:
- bootmenutimeout=10 - number of seconds to wait for user input before the default OS is started.
- nobootmenutimeout - always wait for user input.
- vncinstall - for headless configurations where the Pi is not attached to a display. Login with a VNC client to the Raspberry IP.
- datadev=device - location where your files are stored (e.g. mmcblk0p2 for SD card, sda1 for USB stick). If this parameter is not present Berryboot will start a new installation.
Standard Linux options (like "quiet"):
https://raw.github.com/raspberrypi/linu ... meters.txt
Posted: Tue Jan 15, 2013 9:23 pm
by Tibbey
Can I request soft-float Debian?
Posted: Wed Jan 16, 2013 12:48 am
by AddicusT
Tibbey wrote:Can I request soft-float Debian?
I very much agree. Good idea.
Posted: Wed Jan 16, 2013 8:50 am
by antonholmstedt
I've made a soft float debian for Berryboot, uploading it now
Posted: Wed Jan 16, 2013 9:01 am
by antonholmstedt
Here it is, soft float Debian:
http://ge.tt/4J3u3ZV/v/0
Posted: Thu Jan 17, 2013 10:30 pm
by AddicusT
OS Install From USB
Posted: Fri Jan 18, 2013 6:08 am
by EluZioN
Hello All,
Every image I install from USB results in a boot error of "fsck.ext4: No such device or address while trying to open /run/rootdev". This occurs on pimame and raspbian. I have made these images with squashfs on a debian VM using kpartx and also mounting the extracted image inside a download img. I have tried creating the squashfs image mounting read only and also without the ro flag in mount.
The reason I am trying to install from USB is two-fold, one the menu doesn't have pimame, secondly (and most important), every time I try to update an install (if previously downloaded, raspbian, openelec) it corrupts something and renders the pi unbootable. I can replace the berryboot files (minus the config.txt) and it will boot again. I guess the updaters mess with the berryboot files?
Any suggestions are appreciated. I have spent a few days on this setting up the VM, etc and am confident I have everything right, but I cannot get the OS's to load after install from USB.
Also, is it possible berryboot can be updated to use a standard downloadable image for install?
Thank You,
EluZioN
Re: OS Install From USB
Posted: Fri Jan 18, 2013 12:49 pm
by Max
Between mount and mksquashfs, try commenting out the lines in /mnt/etc/fstab
Commenting out the entry for the root filesystem should prevent fsck being executed. The root file system is already mounted read-write by Berryboot, so you don't need it.
And commenting out the /boot entry will prevent update software from messing with the Raspberry firmware (which lacks binary compatibility, and doesn't always get along that well with Linux kernels that were build for a different version).
Posted: Fri Jan 18, 2013 8:32 pm
by Cromfel
Hello everyone
Sorry if Im asking stupid question. But I installed BerryBoot on my SD card. Now I have FAT32 USB stick where Idownloaded .img containing distro. But the berryboot does not recognize my USB.Should it pop up in the menu or is there some linux specific folder I need to search for to access the img?
Or should I just try other USB stick? Or does it allow to install USB stick content from windows system to the SD card?
Posted: Fri Jan 18, 2013 8:36 pm
by Max
Cromfel wrote:But the berryboot does not recognize my USB.Should it pop up in the menu or is there some linux specific folder I need to search for to access the img?
From first page of this thread.
Hold down mouse button over "add OS"
Do make sure the images are in Squashfs format, or it is not going to work.
No, only using Linux systems.
In that case you can copy the image to the /images folder on the SD card.
Posted: Fri Jan 18, 2013 9:25 pm
by Stolen Goods
Is there a chance we'll be seeing a repo upload of the Raspbian Chameleon Remix anytime soon? Would love to see that as it's far easier to install than any other emulator.
Posted: Fri Jan 18, 2013 9:57 pm
by Cromfel
It seems I had broken USB stick because on other stick the IMG was available. But as you noted, it gives error of the IMG being in wrong format (Not this SF something format).
So how should one proceed to get the right IMG format? I dont have linux installed anywhere and the network list doesnt offer the right distro (pibang).
Could I have installed the pibang without the berryboot? Was that unnecesary since I only intend to just get the PiBang running.
Posted: Fri Jan 18, 2013 10:03 pm
by Max
Cromfel wrote:Could I have installed the pibang without the berryboot? Was that unnecesary since I only intend to just get the PiBang running.
If you only want Pibang, and do not want to give any other distribution a try, you do not need Berryboot.
Can write your image to SD card with win32diskimager or similar tool.
Posted: Fri Jan 18, 2013 10:06 pm
by Cromfel
Max wrote:Cromfel wrote:Could I have installed the pibang without the berryboot? Was that unnecesary since I only intend to just get the PiBang running.
Thanks! I will try it out directly.
Posted: Fri Jan 18, 2013 10:14 pm
by AddicusT
Is this in squashfx format, because it doesn't work.
Posted: Fri Jan 18, 2013 11:31 pm
by antonholmstedt
Yes it is, and it boots in berryboot for me. What happens when you start it?
Anyone else that have tried it?
