prosperer
I can't reformat or burn new image on my noobs sd card
Tue Dec 01, 2015 10:22 am
So since yesterday i try to format my sd cards that come with noobs preinstall without any sucess. Below is what i already try to format it
- Gparted
- DD
- win32diskimager
- bootice
Gparted failed on last step
[b]
Create Primary Partition #1 (ext4, 7.35 GiB) on /dev/sdd  00:00:00    ( ERROR )
create empty partition  00:00:00    ( ERROR )
libparted messages    ( INFO )
Can't have overlapping partitions[/b].
dd
no no error but the noobs files still inside the sd card
win32diskimager
no error, success write the img into the sd card but according to w32diskimager but the noobs files still exist inside the sd card
bootice
pop up some error when i want to single partition format it didnt remember what the error
I can copy paste something inside the card without problem but after unmount the card the copy paste just now dissapear.
When i try to boot it, the rainbow screen appear and after that the white screen and mouse cursor in the middle that stuck there forever.
So is my sd cards can't be use anymore or is there something i can do to fix it?
here my fdisk -l for the sd card
Disk /dev/sdd: 7892 MB, 7892631552 bytes
4 heads, 16 sectors/track, 240864 cylinders, total 15415296 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x000d25fe
   Device Boot      Start         End      Blocks   Id  System
/dev/sdd1            8192     3009765     1500787    e  W95 FAT16 (LBA)
/dev/sdd2         3014656    15349759     6167552   85  Linux extended
/dev/sdd3        15349760    15415295       32768   83  Linux
/dev/sdd5         3022848     3350527      163840    c  W95 FAT32 (LBA)
/dev/sdd6         3358720     5732351     1186816   83  Linux
/dev/sdd7         5734400     5898239       81920    c  W95 FAT32 (LBA)
/dev/sdd8         5906432     9582591     1838080   83  Linux
/dev/sdd9         9584640     9707519       61440    c  W95 FAT32 (LBA)
/dev/sdd10        9715712    15337471     2810880   83  Linux
hansotten
Re: I can't reformat or burn new image on my noobs sd card
Tue Dec 01, 2015 12:44 pm
Imaging software like WIN32DiskImager (Windows) or dd (Linux) normally does not need formatting before writing.
Two options to clear a non-cooperative SD card that always worked for me:
- https://www.sdcard.org/downloads/formatter_4 SD Formatter
- place the card in a digital photo camera and do a complete erase
When the imaging software then keeps complaining the SD card has to be in very poor state ..
http://duinorasp.hansotten.com for Raspberry Pi and Arduino and ESP8266
http://retro.hansotten.nl for retrocomputing with the 6502 cpu
prosperer
Tue Dec 01, 2015 1:20 pm
Thank you for your respond, and i forgot that i already try wipeout the sd card with sony camera but like before the noobs still stubborn :? dont want to go away from the card :P
i'll try SD Card Formatter later and will come back and report about the progress :D
prosperer
Tue Dec 01, 2015 2:11 pm
So SD Card Formatter also fail for me, it say that my card is write protected. I already try to unlock the sd card using the adapter and also try the cmd tutorial that i find online to unlock the card
hansotten
Tue Dec 01, 2015 2:35 pm
prosperer wrote:So SD Card Formatter also fail for me, it say that my card is write protected. I already try to unlock the sd card using the adapter and also try the cmd tutorial that i find online to unlock the card
IF SDformatter complains about write protect I really suspect the hardware write protect lock of your adapter is stuck.
MicroSD cards do not have a physical lock, only normal size SD cards have that, including adapters for mini/micro sd cards.
Did you try another SD card reader? Another adapter? Do other SD cards allow writing? And are you sure the adapter is ok and in the un protect state?
prosperer
Tue Dec 01, 2015 3:50 pm
I already try 3 card reader with all no success, after all the attempt to format the card, i try to boot the card on pi by pressing shift key before the rainbow screen appear and it success goto recovery mode but it take like 2minute to go there and there i can't select what distro i want cause it blank but i can move my mouse freely and only option is press esc key that boot onto openelec and stuck there until now
Another adapter?
i only can find 1 adapter that works properly on my camera
my other sd card (16gb) i already writing on it couple of times yesterday
i got 1 adapter that works that being used on the camera and 1 that already can be used cause window,linux and camera can't detect it so i think the camera sd adapter is working fine and it on the unlock when i try to format it again.
so i check again and the openelec logo gone and blankscreen, so i wonder if the card can boot that far why i can write or reformat it :?:
