The advertised clock frequency for Pi Zer0 is 1GHz, but the default setting determined through /boot/config.txt or raspi-config seems to be 700MHz, whatever the hardware.
I'm guessing the Pi Zer0 needs to be set to the higher clock speed and it's not automatic.
Is this correct or did I miss something?
Pi Zer0 clock frequency
Neil Matthews
Lost count how many of As, Bs, APluses, BPluses, Pi2s and now a couple of Zer0s.
Get your E-paper HAT at www.percheron-electronics.uk/shop
Re: Pi Zer0 clock frequency
Did you undertake a fresh install of Raspbian Wheezy ?BigNeilM wrote:The advertised clock frequency for Pi Zer0 is 1GHz, but the default setting determined through /boot/config.txt or raspi-config seems to be 700MHz, whatever the hardware.
viewtopic.php?f=63&t=126849&start=200#p852351
My other Linux machines are a ChromeBox & Intel CoreDuo Desktop
No. I'm using the latest and greatest Raspbian Jessie.
pi@raspberrypi:~ $ lsb_release -a
No LSB modules are available.
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 8.0 (jessie)
Release: 8.0
Codename: jessie
pi@raspberrypi:~ $ uname -a
Linux raspberrypi 4.1.13+ #826 PREEMPT Fri Nov 13 20:13:22 GMT 2015 armv6l GNU/Linux
Release: 8.0
Codename: jessie
Neil Matthews
